crosbystills Posted December 23, 2011 Share Posted December 23, 2011 I believe the DCC socket is in the Tender on this Locomotive. However I can see no visible means of access. Does anyone have advice? Link to comment Share on other sites More sharing options...
poliss Posted December 23, 2011 Share Posted December 23, 2011 Have you looked in the downloads section of the website? btw, aren't you talking to nash? Link to comment Share on other sites More sharing options...
Rog RJ Posted December 23, 2011 Share Posted December 23, 2011 I think the top should just pull off.Have a look at this https://www.hornby.com/filelibrary/download/?FileID=199 I know it's not the same model but the diagram of the tender should help. Sometimes helps if you use a small screwdriver to carefully prise one end up slightly first. Some tenders have a screw hidden under the coupling if they are not clip fit. Link to comment Share on other sites More sharing options...
crosbystills Posted December 23, 2011 Author Share Posted December 23, 2011 Rog (RJ) said:I think the top should just pull off.Have a look at this https://www.hornby.com/filelibrary/download/?FileID=199 I know it's not the same model but the diagram of the tender should help. Sometimes helps if you use a small screwdriver to carefully prise one end up slightly first. Some tenders have a screw hidden under the coupling if they are not clip fit. Link to comment Share on other sites More sharing options...
crosbystills Posted December 23, 2011 Author Share Posted December 23, 2011 Great stuff, I,m in! There is a small rectangular hole in the front of the tender. It is in the black part so is difficult to see. I relesed the rear pivot screw holding the Loco to tender connecting bar, this makes easier to get at the small hole. Insert a watchmakers screwdriver and BINGO.Thanks again. Link to comment Share on other sites More sharing options...
