David55 Posted December 28, 2011 Share Posted December 28, 2011 Hi AllMy computer which is currently running XP has decided to meet its maker.I have read somewhere that on windows 7 there has been a problem with the elite. There was also something about 32 and 64. Question is: if I get windows 7, which is the best one and will I be able to re install the Railmaster disc on it or will I need a new code. I have a back up system, will this put my plans/trains back on automatically or will there be a problem because I have run this on XP?. Link to comment Share on other sites More sharing options...
poliss Posted December 28, 2011 Share Posted December 28, 2011 The best Windows 7 is Windows XP. Bought a new laptop with Windoze 7 on it. Did I buy Wondoze 7 for my ailing desktop? No way Josie, bought an XP disk for it. Link to comment Share on other sites More sharing options...
Mike_G Posted December 29, 2011 Share Posted December 29, 2011 Hi Daviddrivers are differentI run with Win7 ( 64bit )with correct drivers ( see notice on this site ) should be no problemI have the dvd version and it is now timed out for some reasonto install on a different computer you need to deregister it on the first oneas you cant do this dur to it waving its legs in the aircontact customer service and they will deregister it for you at their endthen do the installdont forget helpline/customer service closed 16:00 Fridays and dont open again till MondayrgdsMike Link to comment Share on other sites More sharing options...
Augustus Caesar Posted December 29, 2011 Share Posted December 29, 2011 Hi DavidBeing a PC techie of many years standing I can safely tell you that Windows 7 is a very good OS compared to XP. If you decide to go down this route then 64 bit is better, faster and safer than 32 bit. It will also 'future proof' you when buying newer software/hardware etc.Windows XP is an excellent system for helping to identify and diagnose faults with so much stuff. There are an abundance of tools that will aid in that area too. The interface is simple and easy to find one's way around and doesn't demand huge drive space. However, it is not the most stable OS and recovery can be a nightmare depending upon what crashes the system.Windows Vista is Microsoft's first attempt at a Win 7 type OS and because of all the issues surrounding drivers and User Access Controls (UAC's) for security it never really took off. It became a techies nightmare.Windows 7 is much improved and far more stable than the previous two. It has drawbacks with certain drivers for not so new hardware but this will be the case for some time even when Windows 8 reaches us soon. However, having said that, most hardware is now covered inline by Windows or drivers are generally available. It rarely crashes as opposed to Windows XP and if anyone tells you different then maybe their system needs looking at (no offence intended). First of all make sure your current hardware can handle it. The motherboard is most crucial. If it has drivers available for it for Win 7 64 bit your almost there.The Elite has no real issues with Windows 7 either 32 or 64 bit but some folk cannot get the drivers or firmware installed properly but this is also true for Windows XP. It can take a few attempts to load the firmware upgrades in either but it can be done.What some folk won't say when they are used to a system is that they don't like, or want, to change to another. This is very typical of us and change doesn't come easy to some. The interface on Windows 7 is totally different to Windows XP but once you know your way around it will seem easier and it is in many ways.As Mike says above you will need to contact support to deactivate your software and then you can reinstall with administrator rights and activate once more with the updates included.I hope this helps you decide one way or another and am glad to offer this advice. Link to comment Share on other sites More sharing options...
poliss Posted December 29, 2011 Share Posted December 29, 2011 If Windoze 7 is so good why can't it run a simple thing as my USB optical mice? I have two that run perfectly fine on XP but don't work on Windoze 7. Am I supposed to go out and buy new ones?Like every new version of Windoze the program is bloated and a memory hogger. Link to comment Share on other sites More sharing options...
Mike_G Posted December 29, 2011 Share Posted December 29, 2011 Hi Polissmay be your mouse is USB-1 ( you find this on some early XP Systems )mind you should still work may be you need different driversgoto the web site of the mouse manufacturer and see if there are updated driversif no win7 ones try Vista Driversmost times i get problems with my win7 its cos of drivers, or i did something wrongor forgot to do something,,, like run as admin,,, ican asure you win7 is the best since Win2000Pro, I admit that i sometimes revert to the office XP Pro to do something,, because its not so security minded,, but most all my software/hardware runs on win7 those that dont is normaly a driver problem and gave problems in Vista as wellrgdsMike Link to comment Share on other sites More sharing options...
poliss Posted December 29, 2011 Share Posted December 29, 2011 Both are USB2 mice, bought long after the PC. Both are Plug and Play,(or Plug and Pray) no drivers required. Checked the manufacturers website, no new drivers there.Didn't loads of PC Techies test Vista before it came out? It was only when real people tried it that they found out it was a pile of pants. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted December 29, 2011 Share Posted December 29, 2011 Not all mice and other bits and pieces like keyboards will work under Windows 7 even if USB2. Some manufacturers churn out such rubbish and claim it works on a kettle plugged into a farm yard tractor!!! Seriously, it is likely a driver issue even though it is said to work with Win 7. If no drivers can be found then that means that the system is using generic Microsoft drivers written as a courtesy for that hardware. It will not have the full capabilities of the driver written for XP by the manufacturer though. This holds true for a lot of hardware used under Vista and Win 7. Very occasionally you may be able to move the mouyse to a hub or another port and find it works a lot better. Some motherboards front USB ports work rather better than the rear ones. So it's not just down to Windoze as you put it! :) Try running them with Service Pack 3 compatibility even.Some techies test stuff with blinkers on I must say. It is usually the general public in most cases that find faults with most computer related stuff. When I test anything I look at it all from a customer's point of view and then mine and give the best of both where possible.Windows is bloated and always has been but you can switch stuff off and control how the system uses its memory etc either on the hard drive for caching or its RAM. If Linux was that much better then Bill Gates wouldn't be as rich as he is. Linux is excellent but not good for field testing etc.Anyway, David merely wants to know if his gear will work well with Win 7. Yes mate - it will... very well. Link to comment Share on other sites More sharing options...
David55 Posted December 30, 2011 Author Share Posted December 30, 2011 Thanks for all of your replies. One Question:When you de activate railmaster and re activate it, does it keep all the info i.e. my layout, trains etc.Happy New YearDavidNot all mice and other bits and pieces like keyboards will work under Windows 7 even if USB2. Some manufacturers churn out such rubbish and claim it works on a kettle plugged into a farm yard tractor!!! Seriously, it is likely a driver issue even though it is said to work with Win 7. If no drivers can be found then that means that the system is using generic Microsoft drivers written as a courtesy for that hardware. It will not have the full capabilities of the driver written for XP by the manufacturer though. This holds true for a lot of hardware used under Vista and Win 7. Very occasionally you may be able to move the mouyse to a hub or another port and find it works a lot better. Some motherboards front USB ports work rather better than the rear ones. So it's not just down to Windoze as you put it! :) Try running them with Service Pack 3 compatibility even.Some techies test stuff with blinkers on I must say. It is usually the general public in most cases that find faults with most computer related stuff. When I test anything I look at it all from a customer's point of view and then mine and give the best of both where possible.Windows is bloated and always has been but you can switch stuff off and control how the system uses its memory etc either on the hard drive for caching or its RAM. If Linux was that much better then Bill Gates wouldn't be as rich as he is. Linux is excellent but not good for field testing etc.Anyway, David merely wants to know if his gear will work well with Win 7. Yes mate - it will... very well.[/reply] Link to comment Share on other sites More sharing options...
Mike_G Posted December 30, 2011 Share Posted December 30, 2011 well no it wont in your case cos you will be installing ona completly new computerall your data is on the hard drive in the dead onemaybe you can take the old drive out and put it in the new one asa second drive,, anyway should not take so long to set your track and engine data bace up againall part of the funbest of luckMike Link to comment Share on other sites More sharing options...
David55 Posted December 30, 2011 Author Share Posted December 30, 2011 [reply]Mike_G said:well no it wont in your case cos you will be installing ona completly new computerall your data is on the hard drive in the dead onemaybe you can take the old drive out and put it in the new one asa second drive,, anyway should not take so long to set your track and engine data bace up againall part of the funbest of luckMikeWith this also being my works computer, I do have an external hard drive which backs up nightly. Will this have stored the data? Link to comment Share on other sites More sharing options...
Mike_G Posted December 30, 2011 Share Posted December 30, 2011 depends if you set the backup back up every thingplug it in and seeis it a straight copy or an encoded backupif encoded you willneed to install the same backup software to read the backupdiskplug it in and seeif you find a folder called railmasteryour layout will be there in the name you called itif you install railmaster on the new one,, you could then possibly copyall the old files across overwriting the new setupthen you wouldhave everything as you left itworth a try nothing to lose everything to gainrgdsMike Link to comment Share on other sites More sharing options...
Kenneth_Brattey Posted December 30, 2011 Share Posted December 30, 2011 AugustusCaesar said:Hi DavidBeing a PC techie of many years standing I can safely tell you that Windows 7 is a very good OS compared to XP. If you decide to go down this route then 64 bit is better, faster and safer than 32 bit. It will also 'future proof' you when buying newer software/hardware etc.Windows XP is an excellent system for helping to identify and diagnose faults with so much stuff. There are an abundance of tools that will aid in that area too. The interface is simple and easy to find one's way around and doesn't demand huge drive space. However, it is not the most stable OS and recovery can be a nightmare depending upon what crashes the system.Windows Vista is Microsoft's first attempt at a Win 7 type OS and because of all the issues surrounding drivers and User Access Controls (UAC's) for security it never really took off. It became a techies nightmare.Windows 7 is much improved and far more stable than the previous two. It has drawbacks with certain drivers for not so new hardware but this will be the case for some time even when Windows 8 reaches us soon. However, having said that, most hardware is now covered inline by Windows or drivers are generally available. It rarely crashes as opposed to Windows XP and if anyone tells you different then maybe their system needs looking at (no offence intended). First of all make sure your current hardware can handle it. The motherboard is most crucial. If it has drivers available for it for Win 7 64 bit your almost there.The Elite has no real issues with Windows 7 either 32 or 64 bit but some folk cannot get the drivers or firmware installed properly but this is also true for Windows XP. It can take a few attempts to load the firmware upgrades in either but it can be done.What some folk won't say when they are used to a system is that they don't like, or want, to change to another. This is very typical of us and change doesn't come easy to some. The interface on Windows 7 is totally different to Windows XP but once you know your way around it will seem easier and it is in many ways.As Mike says above you will need to contact support to deactivate your software and then you can reinstall with administrator rights and activate once more with the updates included.I hope this helps you decide one way or another and am glad to offer this advice. Link to comment Share on other sites More sharing options...
Kenneth_Brattey Posted December 30, 2011 Share Posted December 30, 2011 I am also using Windows 7 64 bit in evaluation mode with no problems. I would be careful though in saying that any operating systems is "future proof". I remember buying a PC about 10 years ago which was being marketed as "future proof". It was out of date within two years of purchase! Link to comment Share on other sites More sharing options...
Mike_G Posted December 31, 2011 Share Posted December 31, 2011 well thats market hypein fact most IT equipment is out of date before it even gets to the shopsif you wait for the 'BEST ONE EVER' you will wait for everjust get the best you can afford that does the job you whantI have a whole room full of 'THE BEST ONES' dating back to the 70sHow about a Radio Shack TRS-80 Model 348 K ramblack and white screenno hi res graphics ( block pixels 124 x 84 )2 disk drives ( 5.5inch paper floppys ) screen, keyboard, disc drives all built in 1 unit1973 1850 pound sterlingcomplete with word prosessor and visicalcstill worksrgdsMike Link to comment Share on other sites More sharing options...
David55 Posted January 4, 2012 Author Share Posted January 4, 2012 Hi AllWent with windows 7 64 bit.All went ok till it said MCI32.OCX was missing. Time to phone a friend. He came over and after a couple of E Mails to Hornby Care it was sorted. He also copied all my info on so all running fine.One thing I have noticed which I have seen somewhere else on this forum is that if you are using the buttons to run the trains and then move the slider the screen locks.Anyone know if there is a quick fix.CheersDavid Link to comment Share on other sites More sharing options...
Mike_G Posted January 4, 2012 Share Posted January 4, 2012 Hi DavidHave not seen that happenRailmaster does say when programing to use the buttonsand not the slider,, one thing i did find is that if you use the button and then try to usethe slider it will revert straight back to the button setting, some times you have to try several times before it will accept the slider setting,,, but the other way using the slider and then pressing a button option works right awaytry it and seeif you set up the shunting speed and the max speed in Railmasterand set your speed curve up in the decoder,, i have found it unnessasary to use the slidershunt/cruise/stop do it welli have all my freight locos sett with a 5 for shuntthey crawl along very slow and stop imidiatly you click stopyou will find the best setting to suit you with a bit of practicehave funMike Link to comment Share on other sites More sharing options...
stevecamden Posted January 4, 2012 Share Posted January 4, 2012 I think we need another update of RM soon to sort out all these little 'strange quirks' and oddities. I know its not easy to make this software, but I do wonder sometimes if the people doing the Elite Firmware upgrade speak to the guys writing Railmaster.Having said that, if Hornby get it right with the sensors etc, then they will be market leaders for Train control. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted January 4, 2012 Share Posted January 4, 2012 Just a quick repose to say that when I say 'future proof' I did enclose the words in double quotes. No system will ever be truly fp so hopefully I was not taken too literally! :)One small point - if the screen is freezing using RM then ensure all updates are installed for the system as well as hardware like the video card. Link to comment Share on other sites More sharing options...
David55 Posted January 4, 2012 Author Share Posted January 4, 2012 What I omitted was that it was a mix of info from this site and hornby care, so thanks to everyone.Unfortuneatly I am only a pc user and do noy know what video card is. I presumed by updating to 1.3 version everything was in place.Another thing that has always happened is that I can click on shunt on one train, but it will shoot back to my previous command. This can happen several times, the only thing that seems to cure it is by double clicking.All your help now and in the past is much appreciated.RegardsDavid Link to comment Share on other sites More sharing options...
