geoffb41 Posted December 30, 2011 Share Posted December 30, 2011 Probably more than half my points have stopped changing if I do it thru railmaster.Some still work ok but most don't.Yet i can select that point no. and change it on the elite and they work fine Also loco control from railmaster is fine.Tried removing some of the non working ones in design and putting them back in but still the same result.Fine on the elite but no go on railmaster.A few have also lost their direction arrows in the track plan.Only cause i can think of is that i did the railmaster version upgrade a few days ago.Any help appreciatedgeoffb Link to comment Share on other sites More sharing options...
Mike_G Posted December 30, 2011 Share Posted December 30, 2011 no its happend to me a few times prior to the upgraderailmaster sends the pulse 2 times to each pointmaybe the cdu is not recharging fast enoughyou can change it in the ini fileits normaly set by defult at 0.75seci have mine at 1.5secnot had the problem sincesome of my route are cascaded with 3 or 7 points some are 2 conected to 1 decoder outlettry it and see,, nothing to lose,, you can always put it backfind a setting to suit yourgdsMike Link to comment Share on other sites More sharing options...
geoffb41 Posted December 30, 2011 Author Share Posted December 30, 2011 thanks mike but ini file timer was set at 1.5.Don't think its a cdu problem as they change fine from the elite and i don't even get a click when i try to change them with railmaster.They did work before with railmaster and haven't really changed anything so no idea why they don't work now.they show on the track plan with correct no.s and and some on a decoder will work with railmaster and the others don'tin one place have three in a row not working so just created a test plan with these three and same story.They change fine with the elite but nothing if i try with railmastergeoffb Link to comment Share on other sites More sharing options...
stevecamden Posted December 30, 2011 Share Posted December 30, 2011 I'd suggest an Elite Reset, with everything disconnected from the PC ( USB cable etc) Link to comment Share on other sites More sharing options...
geoffb41 Posted December 30, 2011 Author Share Posted December 30, 2011 thanks steve tried reset but still the samegeoffb Link to comment Share on other sites More sharing options...
stevecamden Posted December 30, 2011 Share Posted December 30, 2011 HiYou are running the Elite in Standard mode and not Classic? When you do a reset it puts it to Classic mode by default - RM needs Standard mode.I found that running RM with the Elite 1.4 in Classic mode corrupts one or both somwhow - anyway apologies if I am just telling you what you know already!Can only think to check the wiring and create a new small point layout and allocate the port on the decoder etc and try that. If that still does not work, then I would probably reset the ports on the accessory decoder.But watch out for this Classic Elite thing - I found that all my point numbering went crazy with RM1.3 and Elite 1.4 because I ran it in Classic mode by accident.Steve Link to comment Share on other sites More sharing options...
Mike_G Posted December 30, 2011 Share Posted December 30, 2011 Could be your problemhave heard this before but not seen itwhen i updated mine it came back on in standard modeall my points are working okit my engines that have gone wrongseem to have lost all the exceration/deceleration settinggo from stand still to crazy speed in a eye blinkjust in the process of putting them on the programing trackand run them through Decoder Proproblem is i have lost some of the papers with the settings on itRgdsMike Link to comment Share on other sites More sharing options...
geoffb41 Posted December 31, 2011 Author Share Posted December 31, 2011 thanks guys your help very much appreciated.You were right.The elite upgrade must have changed it to classic mode.Put it back to standard and they all working now.rgds,geoff Link to comment Share on other sites More sharing options...
SailorSam Posted January 6, 2012 Share Posted January 6, 2012 On the subject or point control with RM and the Elite etc, which i have on an XP pro pc with a touch screen. I have just got one R8247 decoder set up at present addressed at 1 (ports 1-4) as per instructions. There is 1 point motor on each port, on the layout i have 2 points which should fire together like a crossover. What is the best way to do this, have two motors on 1 port, or have 2 ports with the same address. If the latter then how do you set that up on RM, do you set up the 2 ports with the same No. in the design options. and would you have both points with control buttons or just the one, i have 1 set per point at present.The point decoder is powered from a booster + Xpressnet cable from the Elite. Other posters on here must have similar situations on their layouts. I tried 2 motors connected to 1 port but they didn't seem to get adequate power to change so i put them back to seperate ports. If they are not getting adequate power from the booster to fire 2 at once, then i was wondering if the output from the booster wasn't equal to the track output power from the Elite. I would have thought a booster would be equal given it's supposed to power a seperate section of track to the main controller.Cheers Sailorsam Link to comment Share on other sites More sharing options...
geoffb41 Posted January 7, 2012 Author Share Posted January 7, 2012 i have two points from the same port working ok off the 8247 from the elite .In railmaster i only added 1 and clicking this changes both.Maybe try powering it from the elite.I tried running the decoders off my booster but its showing 22 volt and the closest decoder to the booster gets pretty warm and mostly doesn't work.have gone back to running them off the elite till i sort t outrgds,geoffb Link to comment Share on other sites More sharing options...
stevecamden Posted January 7, 2012 Share Posted January 7, 2012 You can run two motors off one port for a cross-over easily. Just make sure that the polarity is the same for each point. If the motor is not on the same side then just swap the red and green wires over of one of the point motors.Steve Link to comment Share on other sites More sharing options...
Mike_G Posted January 7, 2012 Share Posted January 7, 2012 Were i have more than 1 point (cross over or Passing loop )i take the wire from 1 oitput on the decoder to a domino blockthen from here i take wires to both point motors that chaange togetherthen in railmaster witch ever point you select, the other one changes at the same timeif you find that they are changing and show different directions change the wires over on 1 of the points, or in railmaster change the polarity on one of themit will also pay to go into the railmaster ini file (in notpad)and change the defult setting from 0.75 to 1.50rgdsMike Link to comment Share on other sites More sharing options...
