vito_bellissimo Posted October 6, 2017 Share Posted October 6, 2017 Hi all, can I use side mounted point motors on my electrofrog point on DCC? I wish to have a polarity switch with it. Link to comment Share on other sites More sharing options...
96RAF Posted October 6, 2017 Share Posted October 6, 2017 There are two way s to mount a switch when using side mount point motors: 1. use a separate microswitch operated by the tie bar on the side opposite the motor. 2. Mount (glue) a modified PL-30 switch (snip off the mounting clips to give a flat switch) directly under the point and fit a track pin through the point tie bar into the switch slider boss. See here and here Rob Link to comment Share on other sites More sharing options...
Flashbang Posted October 6, 2017 Share Posted October 6, 2017 HiThere is a third option and that is to use a twin coil latching relay worked by the pulse of power going to the motor to move it over. You can buy these ready made from Gaugemaster - GM500 or their GM500D for use with an accessroy decoder Example... http://www.gaugemaster.com/item_details.asp?code=GM500&style=main&strType=&Mcode=Gaugemaster+GM500 or make your own with a twin coil latching relay and three diodes, see... http://www.brian-lambert.co.uk/Electrical%20page%202.html#Unable Normally a twin coil latching relay has two independent sets of change-over contacts. One set can be used on electrofrog points for frog polarity switching and the other for whatever is needed - signal aspect control or panel indications etc. BTW. I think RAF96 means the Peco PL-13 switch not PL-30. 😉 Link to comment Share on other sites More sharing options...
96RAF Posted October 6, 2017 Share Posted October 6, 2017 Absolutely correct FB - but edit timed out after I spotted itBTW. I think RAF96 means the Peco PL-13 switch not PL-30Rob Link to comment Share on other sites More sharing options...
