Evzone Posted November 15, 2017 Share Posted November 15, 2017 What ever happened to the hump back bridge. Used to have one many many years ago in a set that had two MininCoopers with it. If I could get hold of an old one would it be compatible current sport track? Link to comment Share on other sites More sharing options...
harrison152 Posted November 15, 2017 Share Posted November 15, 2017 It would but you would need the classic/sport converters, I beleve the code was c8222Scalextric no longer do these so would have to get off the bay. Link to comment Share on other sites More sharing options...
Evzone Posted November 15, 2017 Author Share Posted November 15, 2017 Thanks, your advice is appreciate. Btw does the same apply for the old Le Mans start and chicanes? Link to comment Share on other sites More sharing options...
harrison152 Posted November 15, 2017 Share Posted November 15, 2017 Yes. you need a converter ether end of the classic track that is being connected to sport track. Link to comment Share on other sites More sharing options...
Blagard-01 Posted November 15, 2017 Share Posted November 15, 2017 You should also be aware that the old classic track has a shallower slot than the Sport Digital. So modern car guides can catch if not trimmed down. Link to comment Share on other sites More sharing options...
harrison152 Posted November 16, 2017 Share Posted November 16, 2017 You should also be aware that the old classic track has a shallower slot than the Sport Digital. So modern car guides can catch if not trimmed down.Thanks Blagard-01 I forgot about that. Link to comment Share on other sites More sharing options...
Andy P. Posted November 16, 2017 Share Posted November 16, 2017 I have seen people take the "birdge" left and right section and then take a standard Sport straight and carefully bend it to fit on the bridge bits. Link to comment Share on other sites More sharing options...
Mac999 Posted January 16, 2020 Share Posted January 16, 2020 make your own hump back bridge using sport track,it can be done 😉 Link to comment Share on other sites More sharing options...
