6667s Posted December 10, 2017 Share Posted December 10, 2017 R3388tts cairn gorm, i have tried moving the small switch under the loco with the lights on and it makes no difference what should happen. Link to comment Share on other sites More sharing options...
Howbi Posted December 10, 2017 Share Posted December 10, 2017 There are other versions of this model without decoders fitted when the light switch will work..........when a decoder is fitted it takes control of the lighting via your function key........that's my assumption........HB Link to comment Share on other sites More sharing options...
6667s Posted December 10, 2017 Author Share Posted December 10, 2017 There are other versions of this model without decoders fitted when the light switch will work..........when a decoder is fitted it takes control of the lighting via your function key........that's my assumption........HBHi HowbimanAfter i posted my question i had a further investigation upon moving the switch i found that in one position the left headlight was on then flicked the switch then the right headlight came on.thanks for your reply. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted December 10, 2017 Share Posted December 10, 2017 I thought the switch turned off the tail (red) lights when there was anything being towed.Anyway, you found out what it did! Link to comment Share on other sites More sharing options...
Howbi Posted December 10, 2017 Share Posted December 10, 2017 @66/67's.........we learn something new everyday here...... 😀.........HB Link to comment Share on other sites More sharing options...
6667s Posted December 11, 2017 Author Share Posted December 11, 2017 I thought the switch turned off the tail (red) lights when there was anything being towed.Anyway, you found out what it did!are you into amateur radio 2e0dto looks like intermediate call sign, I'm 2m0fyg. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted December 11, 2017 Share Posted December 11, 2017 Going WAY off topic - Yes I am, 66, but I'm now M0HFF, and have been for a while. Presently no HF, as last winter's storms brought down my radio mast, and I've not yet replaced it.You can find me in QRZ.I'm also a scuba-diver, published author, and fly radio-controlled model aircraft, to which you will find the odd reference scattered amongst the threads on here. Link to comment Share on other sites More sharing options...
