smiley bill Posted December 25, 2017 Share Posted December 25, 2017 Hi all, Merry Xmas to everybody.I have a small collection of cars i keep in a cabinet as a static display, still in boxes never run.I recentely acquired a new Bathurst Legends set with the Falcon/Torana combination. All went well with the setup of the track and running the cars.I decided to run a couple of cars from my cabinet as well however i'm having trouble with one of my other Toranas. It doesn't seem quite as quick as the other cars but on the exit of both hairpin bends (with lane crossovers) it really slows down then has to accelerate again.Any advice on setup/tuning of new cars or what to check re. this problem would be much appreciated.Thanks in advance, Bill. Link to comment Share on other sites More sharing options...
woodcote Posted December 25, 2017 Share Posted December 25, 2017 Hi Bill - could be it's just a slower car... but there are a few things to do that might be causing that hairpin problem. 1) Flashing round the rear wheels. It's just worth looking around the rear wheels and see if any rogue plastic from the mould is interfering with the wheels / tyres. That could be from the body (the wheel arches) or from the chassis. Gently remove it with an emery board / nail file. 2) Gear mesh. Could be the gears aren't meshing too well, especially the 'inline' cars like the Torana. The rear light cable might even be interfering with the gears - I had this problem with a BTCC MG. Take the body off and see whats going on inside. Slowly rotate the rear wheels - see if the gear is sticking on any teeth. If the gear is really sticking on a tooth, I use a tiny flat-headed screwdriver to gently 'shave' the side of the gear tooth until it rotates more freely. Add a little light oil too. Running in the gear with the wheels off the track will help get the gears meshing better. And on the track, the gear mesh will improve with use. 3) Braid plate. Check the braid plate is in the correct position. The braids are held on a flat disk which slots into the guide blade. The disk can become dislodged and move forward slightly, causing issues with connectivity, stuttering etc. Push it back so it sits firmly in the slot in the guide blade and is centred over the round guide blade base. There are some more advanced Tuning Tips here: https://www.scalextric.com/uk-en/five-top-tuning-tip-for-christmas Have fun and Merry Christmas! Link to comment Share on other sites More sharing options...
smiley bill Posted December 25, 2017 Author Share Posted December 25, 2017 Hi woodcote,Thanks for the info., shall check out your suggestions asap.Many thanks, Bill. Link to comment Share on other sites More sharing options...
Andy P. Posted December 26, 2017 Share Posted December 26, 2017 More than likely it is the braids and/or the electrical connection to them. Woodcote gave you the best places to start. Link to comment Share on other sites More sharing options...
smiley bill Posted December 26, 2017 Author Share Posted December 26, 2017 Hi Andy P.,Thanks for your reply, will check out the braids as well.Bill. Link to comment Share on other sites More sharing options...
