Johnboy99 Posted December 25, 2017 Share Posted December 25, 2017 Hi I am 75 and just got my first train a east coast dcame,the only space is in my shed where I keep 3 canaries.it is very dry but cold as the birds don't like heat, what problems do you see me having thanks John.happy Xmas to you all. Link to comment Share on other sites More sharing options...
walkingthedog Posted December 25, 2017 Share Posted December 25, 2017 Hot canaries I guess. Model railways need to be warm and dry. Link to comment Share on other sites More sharing options...
Johnboy99 Posted December 25, 2017 Author Share Posted December 25, 2017 Thanks that is now giving me great concern,the only other option is a small narrow spare bedroom but would only be able to have straight tracks no room for a 6x4 base for track?thanks. Link to comment Share on other sites More sharing options...
Smallteasers Posted December 25, 2017 Share Posted December 25, 2017 Hi, you can have a lot of fun without a circuit. There are some good books around concerning layouts in small places which may give you some alternatives. Try a google search for some inspiration too. Otherwise move the canaries Link to comment Share on other sites More sharing options...
Jimbo1707820979 Posted December 25, 2017 Share Posted December 25, 2017 Hello Johnboy99. Why not have the best of both worlds - use the small bedroom in Winter and the Canary Shed in the other warmer seasons ? I do something similar, not using our garage layout while the weather is cold (and storing the locos inside the house). You could even call a station in the shed "Canary Wharf" . 😀 A Very Merry Christmas to you. Jimbo. Link to comment Share on other sites More sharing options...
Johnboy99 Posted December 25, 2017 Author Share Posted December 25, 2017 Thanks all , Jimbo that's a good idea had not thought of that great idea ,food or thought. Link to comment Share on other sites More sharing options...
mjb1961 Posted December 27, 2017 Share Posted December 27, 2017 Hi johnboy99 ,,,,,,with no disrespect to the other guys on here I can say that I have a fully built and running layout in the shed ,,it isn't insulated or heated and does get hot in the summer and cold in the winter ,I tend to have a break from running it in the coldest of days/months and the same in the summer ,I don't leave any locos or the controller in the shed in the winter time either ,I think you would be OK with your layout in the shed ,,,please let us know what you decide,,,,,,mjb Link to comment Share on other sites More sharing options...
2e0dtoeric Posted December 27, 2017 Share Posted December 27, 2017 Problems - feathers and seed in the works! :-) (Not counting 'bird-bombs'!)If you decide to build in the shed, make sure that you have plenty of under-structure to the boards, so that they cannot warp, sag, or droop.As said, take the electronic parts indoors for the winter, and be aware that card models won't take very kindly to the temperature, even if it is dry in there, so make them portable as well.Just put a simple layout together, and leave it, to see how it over-winters. There's no point in going for fully detailed stuff, if it all falls apart at the first cold snap.Presumably you have mains electric in the shed, so it would be wise to have a BIG, clearly marked, circuit breaker that turns EVERYTHING off, just inside the door, for just in case. Link to comment Share on other sites More sharing options...
37lover Posted December 27, 2017 Share Posted December 27, 2017 When you say the birds don't like heat does that mean you couldn't maintain say a temperature of 10 degrees centigrade? Would that be too warm for the birds over Winter? A simple tube type heater with a thermostat works great, I have one in my garage train room and it easily keeps the minimum temp above 15 degrees. Link to comment Share on other sites More sharing options...
Johnboy99 Posted December 28, 2017 Author Share Posted December 28, 2017 Thanks 37lover yes that would do but the wife has now given me the narrow spare bed room so I am well sorted it's 6ft wide and 12 ft long , Link to comment Share on other sites More sharing options...
2e0dtoeric Posted December 28, 2017 Share Posted December 28, 2017 That's better! Plenty of options in there, from a 'U' shaped end-to-end, to a hole-in-the-middle tail-chaser, with a fold-up hatch for the door. Link to comment Share on other sites More sharing options...
