RailRoo Posted January 1, 2018 Share Posted January 1, 2018 Hi allI've managed to fit a decoder and speaker to my 9f and sounds great but was a bit of an ordeal with limited space. The speaker is in the tender (loco drive) and the decoder (hornby king class R8109) is tight foward of the motor and gearbox. I had to relcate the 8 pin DCC socket from its mount and in hindsight should have just hardwired the decoder and totally removed it. At first the loco was slow at top speed and note that cv5 top voltage is not adjustable so am wondering if I have fitted not suitable decoder. I can see there are different ones for A1 and Tornado class so does any one know if these are more suite to 9f?Thanks in advance Link to comment Share on other sites More sharing options...
96RAF Posted January 1, 2018 Share Posted January 1, 2018 You could try the alternate algorithm on CV150 or even fiddling with the associated CVs that alter motor response. Its all in the manual.Rob Link to comment Share on other sites More sharing options...
jane1707819582 Posted January 1, 2018 Share Posted January 1, 2018 hi the a1 and tornado will have the same decoder,but with different sounds ,so i think it will make little difference to the running of the loco . Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 1, 2018 Share Posted January 1, 2018 There are 'proper' sound decoders for both the regular and Crosti 9f's on (I think) the Loksound site. Just be advised these are high-quality, not TTS decoders, and will set you back about £100 each.You say the loco was slow - well, the 9F is a freight loco, not intended for express use, although it did cope quite well in that function.If you mean slow to start after 'dialling' the speed, it will be - the decoder has to cycle through sound effects before the wheels move, and it won't take off like a startled cat, it will accelerate (and decelerate) slowly.You don't say what controller you are using, so be advised, if the Select, this is a basic unit, and you will not be able to adjust many CV's with it. Link to comment Share on other sites More sharing options...
96RAF Posted January 1, 2018 Share Posted January 1, 2018 If you are struggling to find room for a TTS decoder then fitting an ESU 21-pin unit in will be almost impossible.Rob Link to comment Share on other sites More sharing options...
RailRoo Posted January 9, 2018 Author Share Posted January 9, 2018 Thanks all for your advice .... Im running MRC Prodigy Advance DDC which I think is also called Gaugemaster (think) and am very happy with it but prefer to use elink and railmaster to program CVs on a dedicated track. The speed of my 9f is OK now im used to it and comming from old DC is more in keeping with its scale speed. On another issue......CV29? ........................why is it that sometimes after crossing a point or turmout it will go flat out in opposite direction .......is that the CV29 issue? (im hearing something to do with DC setting) have seached the forum and cant find it Link to comment Share on other sites More sharing options...
96RAF Posted January 9, 2018 Share Posted January 9, 2018 2018 TTS range includes 9f.The flat out into reverse fault sounds like DC running is enabled in CV29.Rob Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 9, 2018 Share Posted January 9, 2018 Agree with Rob it is DC Runaway and can be fixed by turning off DC Running by subtracting 4 from the current value of CV29. But this is curing the symptom not the disease. That will be that you are getting a momentary short crossing the point and is most undesirable in DCC. Check out the back-to-back measurement on all wheelsets for a start. Also consider fitting bus terminators to eliminate the voltage spikes which can happen with shorts. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 9, 2018 Share Posted January 9, 2018 If you are unsure what a 'bus terminator' is as referred to by Fishy above. A worthwhile suggestion by the way. They are also known by other names such as 'RC Filter' or 'Snubber'. You can obtain more details about these on this previous thread..https://www.hornby.com/uk-en/forum/decoder-r8247-problem/?p=2/#post-233144. Link to comment Share on other sites More sharing options...
