Hairos Posted January 16, 2018 Share Posted January 16, 2018 Are there any decent lap counters out there?Ive got the arc one powerbase but had 4 controllers break,so I've gone back to the sport powerbase.Ive tried the C8215 lap counter and I'm pretty sure it didn't work correct. Dan Link to comment Share on other sites More sharing options...
woodcote Posted January 16, 2018 Share Posted January 16, 2018 Dan - You could use the ARC One as a lapcounter and use your Sport powerbase for power & control. Without the controllers plugged in, the ARC One should be isolated from the track - to be absolutely sure, you could unscrew the base panel and snip the wires to the track. Hope that helps. Link to comment Share on other sites More sharing options...
Andy P. Posted January 16, 2018 Share Posted January 16, 2018 No need to snip in most cases. Search for "ARC ONE brake mod" here or on SlotForum and most ARC ONEs have 3 plugs in the base (after you remove the basepalte). Unplug the middle one and it works only as a pit and lap counter.You will void your warranty of course... Link to comment Share on other sites More sharing options...
Hairos Posted January 17, 2018 Author Share Posted January 17, 2018 I was wondering if I could use that.Cheers guys Link to comment Share on other sites More sharing options...
