The Bulldozer Posted February 2, 2018 Share Posted February 2, 2018 Hi,I'm having trouble fitting a TTS decoder to R3572 Class 60.I've run the loco in with 40 minutes each way on a rolling road on dc power adn the loco is running smooth and is responsive. I fitted the TTS decoder last night and test ran it. The sound is working fine but the motor response is not good. My NCE Power Cab has 128 step speed control but I find that nothing much happens up until I get to about 110 of those speed steps. The top speed is very slow - I would approximate that it's doing approximately 30 miles per hour top speed.I've seen other other posts on the forum (and in the decoder manual) regarding speed steps and Back EMF and have made sure that CV10 is set to 128.I've also seen posts regarding CV150/151/152. I've set CV150 to 0, CV151 to 255, CV152 to 1 but this has made no difference. I also found a post saying try CV151 and 152 to 35 but this has made no difference.I tried the decoder in R3487 Class 66 and it responds fine - immediate response and good top speed.I have tried a different decoder (not sound) in the Class 60 and whilst it responds immediately at a low speed step, the top speed is not improved. Can anyone suggest something that might explain this adn help me fix it?Simon Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 2, 2018 Share Posted February 2, 2018 Hi Bulldozer, start by trying CV150 at 1 to get the other motor algorithm, then tweak CVs 153 and 154 which are the same as CVs 151 and 152 when CV 150 is set to 0. Link to comment Share on other sites More sharing options...
jane1707819582 Posted February 3, 2018 Share Posted February 3, 2018 hi bulldozer change your powercab display so it displays the motor current does it seem to be drawing the correct current ?set cv 10 to 0 ,i dont think altering cv 150 will help with this Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 3, 2018 Share Posted February 3, 2018 Setting CV10 to 0 turns off back EMF load compensation entirely and should not be necessary. The Hornby notes say in rare cases reducing it will give smoother low speed operation. This seems weird as at low speed BEMF will still be working unless the CV is reduced to a very low value and this isn’t recommended. There are certainly very many reports on here that changing motor algorithm improves jerky running. Link to comment Share on other sites More sharing options...
The Bulldozer Posted February 3, 2018 Author Share Posted February 3, 2018 Thanks for your replies - late last night, I tried CV150 last night with 153 and 154 set to 35.Repsonse was much improved at low speed stpe but the top speed was not affected.I'll do much more testing tomorrow including seeing what current the loco is drawing.Any suggestions where I should start with the settings for CV153/4 ?Otherwise, it's gonna be try it and see. Link to comment Share on other sites More sharing options...
96RAF Posted February 4, 2018 Share Posted February 4, 2018 This explains the basics behind PID tuning of motors. TTS allows part of this process to be carried out. Read this then reread the explanation in the TTS leaflet.https://tonystrains.com/dcc-motor-control-with-back-emf-and-p-i-d/A bit ‘techy’ but every little information helps us understand what we re fiddling with.Rob Link to comment Share on other sites More sharing options...
jane1707819582 Posted February 4, 2018 Share Posted February 4, 2018 Thanks for your replies - late last night, I tried CV150 last night with 153 and 154 set to 35.Repsonse was much improved at low speed stpe but the top speed was not affected.I'll do much more testing tomorrow including seeing what current the loco is drawing.Any suggestions where I should start with the settings for CV153/4 ?Otherwise, it's gonna be try it and see.alter the values of cv 153/4 by values of 5 up or down until smooth running is achieved , my rule of thumb is if the jerking is whilst accelerating alter 153 . if decelerating alter 154 .of coarse there will be exceptions to the rule !!, please compare the service sheets of your class 60 with the class 40 tts , if similar i will set up my 40 and alter the c.v 'sand try to create a similar fault Link to comment Share on other sites More sharing options...
The Bulldozer Posted February 11, 2018 Author Share Posted February 11, 2018 Thanks for everyone's replies -Rob, The PID/Back EMF info was a very interesting read though not the final solution in this case.Fishmanoz, flipping between the 2 algorithms has smoothed out my lumpy low-speed performance but had no effect on the top speed.Jane2, the class 60 was drawing around about what I was expecting - a bit high perhaps - about 0.5 amps normal with a peak of 0.85. As per above, the CV150 change hasn't had any effect on the top speed - only on the smoothness at low speeds.However, I have made some progress - I found this post on a different forum http://www.rmweb.co.uk/community/index.php?/topic/52016-help-with-nce-powercab/The symptoms were identical to mine so I decided to try the 60 using my e-link (which I am using for the accessory bus). I found the class 60 runs fine on e-link so I know that the problem must be the low track voltage supplied by the Powercab.My options now seem to be1. to upgrade my Powercab with a better Power Supply - I have seen comments that Digitrains do one but that they are currently sold out,2. buy a booster which will cost me more than I paid for the Powercab, or3. perhaps investigate using a tablet as a throtle with e-linkThanks again for your replies,Simon Link to comment Share on other sites More sharing options...
Sultan Posted January 24, 2019 Share Posted January 24, 2019 Having just fitted a Hornby TTS decoder to my R2488 '60026' I am also getting jerky running at speed steps below 10. Interestingly the running is perfectly smooth in both directions with the sound off. I am running NCE Power Cab as my DCC controiller with addition Pro Cab hand set and Engineers throttle. I do not get this behaviour with any other loco currently on my layout.I have disabled DC operation and that has made no improvement.Many decoder fitting guides advise removing any capacitors on PCBs of wired directly across the motor terminals. I am not sure whether this would improve sound running as it does not affect non sound running. To access the capacitor on my particular model will require removal of the PCB and all those lighting wires etc and rewiring to the motor as there is no slack on the capacitor connections. Has anyone on this forum removed the capacitor?I have read alot about this fault on this and other forums and it would appear that this is a programming/manufacturing fault and as such should be rectified by Hornby. Has anyone approached Hornby directly and if so what was their reply?I understand that TTS decoders are much cheaper than Loksound or ESU etc but they must be fit for purpose. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 24, 2019 Share Posted January 24, 2019 I am running NCE Power Cab as my DCC controiller with addition Pro Cab hand set and Engineers throttle..In light of the above, see this post regarding TTS decoders with non Hornby brand controllers:https://www.hornby.com/uk-en/forum/hornby-tts-decoders-reported-problems/ Link to comment Share on other sites More sharing options...
Sultan Posted January 24, 2019 Share Posted January 24, 2019 @chrissafThank you for that. I will give Hornby CS a call. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 24, 2019 Share Posted January 24, 2019 If Hornby CS say that your controller is not one of the ones affected. Then have a look at this previous post. As well as the first post on the page, see also Howbiman's post 5th one down on the page..https://www.hornby.com/uk-en/forum/getting-smooth-running-from-tts-decoders/?p=1. Link to comment Share on other sites More sharing options...
96RAF Posted January 24, 2019 Share Posted January 24, 2019 NCE Powercab is on the fairly long list of controllers Hornby has used for testing but I don’t know about the add on cab controls.Rob Link to comment Share on other sites More sharing options...
