andrew_ball1 Posted February 9, 2018 Share Posted February 9, 2018 I was unable to locate the C1374 Platinum set in Canada so I purchased the C1359 Porsche Le Mans set.Question: what do I need to Purchase to upgrade to ArcPro and run 6 cars? Thanks Andy Link to comment Share on other sites More sharing options...
Andy P. Posted February 9, 2018 Share Posted February 9, 2018 Two Options:IN both you need the ARC PRO upgrade powerbase:https://www.scalextric.com/uk-en/scalextric-arc-pro-powerbase.htmlAnd then 4 more controllers:https://www.scalextric.com/us-en/arc-air-pro-hand-controller.htmlOr you use Slotit buttons and modify the two ARC AIR controllers you have and buy only 2 more ARC PRO controllers.https://www.scalextric.com/uk-en/forum/arc-air-to-arc-pro-controller-upgrade/#post-302435This will of course void any warranties you have...You can sell off the ARC AIR pwoerbase as ARC PRO has all the same features when running in analog mode...Oh and all your cars will need digital chips, either DPR or a retro chip for non DPR cars. Link to comment Share on other sites More sharing options...
andrew_ball1 Posted February 9, 2018 Author Share Posted February 9, 2018 Thanks for the help, so I don't need thishttps://www.greathobbies.com/productinfo/?prod_id=SCA7042 Link to comment Share on other sites More sharing options...
woodcote Posted February 9, 2018 Share Posted February 9, 2018 No. That's the older C7042 Advanced Power Base (APB). The ARC Pro powerbase has replaced the APB as the basis for the Scalextric Sport Digital system. To upgrade to ARC Pro, all you need are the products Andy P listed, plus a second power supply to run six cars. Have fun! Link to comment Share on other sites More sharing options...
andrew_ball1 Posted February 9, 2018 Author Share Posted February 9, 2018 Thanks guys I appreciate the help. Link to comment Share on other sites More sharing options...
andrew_ball1 Posted February 10, 2018 Author Share Posted February 10, 2018 One more question, are the controllers all the same like 2.4 rc transmitters or do I have to specify different chanels/colours? Link to comment Share on other sites More sharing options...
Andy P. Posted February 10, 2018 Share Posted February 10, 2018 Each controller must have its own channel and be paired with a color. Link to comment Share on other sites More sharing options...
