bradley_pethers Posted February 13, 2018 Share Posted February 13, 2018 My Hornby Select controller Version 11-30 refuses to reprogramme my latest Hornby TTS fitted locos off the factory 03 setting. All decorders (Class 20, 31 and Castle) work OK on the 03 setting but refuuse to reprogramme on a separate programming track. The Select controller has previously reprogrammed my Class 40 and 47 TTS locos successfully and continues to reprogramme other non Hornby decorders OK. Help please. Link to comment Share on other sites More sharing options...
96RAF Posted February 14, 2018 Share Posted February 14, 2018 See the discussion herehttps://www.hornby.com/uk-en/forum/tts-sound-with-the-select-controller/?p=1You are advised to contact Hornby via the number at the bottom of the screen to get your Select updated to v1.5, else it will be limited to operating only nine sound functions, not the full range.Also note that v1.3 was to better program ESU sound decoders, so probably helps with TRS as well.Yours is at v1.1.Rob Link to comment Share on other sites More sharing options...
