kenneth_pearson Posted February 24, 2018 Share Posted February 24, 2018 just got original merchant navy with tts sound fitted when i try to use it with my bachmann dynamis with rail controller it wont run or make sounds.i also have a nce procab on another layout which it works perfectly on.i have also found that after running with the procab it will work after a few minutes with the bachmann.i have tried turning off dc mode but it makes no difference.can anyone help ? Link to comment Share on other sites More sharing options...
2e0dtoeric Posted February 24, 2018 Share Posted February 24, 2018 Similar posts to this keep popping up. The Dynamis seems to be incredibly fussy over which decoders will work with it! Link to comment Share on other sites More sharing options...
Chrissaf Posted February 24, 2018 Share Posted February 24, 2018 Kenneth,You may have a TTS decoder with the issues covered by this previous post. Take the official Hornby advice presented in the first post on the page. I believe that some affected TTS decoders are fixed with a firmware update performed F.O.C by Hornby..https://www.hornby.com/uk-en/forum/hornby-tts-decoders-reported-problems/ Link to comment Share on other sites More sharing options...
Howbi Posted February 24, 2018 Share Posted February 24, 2018 @Kenneth...........you could try changing the motor control algorithm, that is by changing CV150 to 1........many have found this to improve performance........HB Link to comment Share on other sites More sharing options...
kenneth_pearson Posted February 26, 2018 Author Share Posted February 26, 2018 thanks for replies decoder now on its way to hornby Link to comment Share on other sites More sharing options...
