Mal-Spain Posted February 28, 2018 Share Posted February 28, 2018 I am all new to this, so forgive me if the question is a bit dumb! I aquired this set second hand, boxed and barely used. There was no indication that it was DCC ready, but when attempting to fit a decoder I discovered the loco, United States lines, did already have a DCC socket. Fitted a small Hornby decoder and it all ran fine on our club track. However, some advice was to remove the capacitor, which you do if it's not DCC ready and are rewiring. I have not done that, so the question is, if it already has a DCC socket is it necessary and should I have removed the capacitor?Also do I need to worry about the lighting in the pullman coaches, is there any need to do anything to restrict the power to the lights?ThanksMalcolm Link to comment Share on other sites More sharing options...
96RAF Posted February 28, 2018 Share Posted February 28, 2018 My first loco....plugged in a decoder and ran it ever since, coaches and all.Rob Link to comment Share on other sites More sharing options...
jane1707819582 Posted February 28, 2018 Share Posted February 28, 2018 hi malthe suppression capacitor can be removed ,as the decoder is also surpressed ,if it is giving you no problem then perhaps don't bother ,the fitted capacitor may interfere with the dcc signal , Link to comment Share on other sites More sharing options...
2e0dtoeric Posted February 28, 2018 Share Posted February 28, 2018 Unless the coach lighting seems very bright, leave them alone! (If it ain't broke, don't fix it!)Can you tell if the coach lights are LED or incandescent bulbs?Depending on how the coach lights are wired up, if LED, you can put a 4K2 resistor in each one, between the power pick-ups and the lights, but it can be a fiddly job.-Although not directly related, have a look at -http://www.hornby.com/uk-en/forum/12v-5050-led-strip-lighting/?p=1/and many other threads in here about installing lighting. Link to comment Share on other sites More sharing options...
Mal-Spain Posted March 4, 2018 Author Share Posted March 4, 2018 Thanks to all for the helpful responsesMal Link to comment Share on other sites More sharing options...
