Johnboy99 Posted March 31, 2018 Share Posted March 31, 2018 Hi All my coaches have plastic wheels please I want to fit some led strips lights in my coach bodies how can I get power to them?Thanks. Link to comment Share on other sites More sharing options...
Howbi Posted March 31, 2018 Share Posted March 31, 2018 This is one solution.......the lights are battery powered and only switch on when movement is detected........ https://www.railroomelectronics.co.uk/Train-Tech/Coach-Lighting/Coach-Lighting-Oo-Gauge/Product-84961.aspx .......the other type is where the lighting is turned on by moving a magnet over the coach roof...... http://www.layouts4u.net/coachlighting.html .........HB Link to comment Share on other sites More sharing options...
Chrissaf Posted March 31, 2018 Share Posted March 31, 2018 And another solution. Replace the plastic wheels with metal axle ones (worth doing anyway even if you weren't trying to fit lighting as the plastic attracts and spreads grime and dirt on the rails). Then fit the metal wheels with pickups. You can either make your own pickups or use the wiper pickup variety made by DCC Concepts. Alternatively combine the two and use DCC Concept replacement brass wheel / axles with pickup springs. These will need painting however to hide the shiny brass finish..PS - DCC Concept 2mm springs are the correct ones for OO gauge rolling stock axles..The DCC Concept brass wheel / spring combo requires two axles and springs on the bogie. The wheels are insulated from the axle on one side only. Thus you fit the two axles opposite to each other such that one spring picks up power from the left side, and the other spring picks up power from the right side..The big advantage I found using the more expensive wheel / spring combo over the wiper version (I have tried and used both). Is that the wiper version although cheaper overall (when wheels are already metal ones) introduce greater drag and can inhibit the wheels from turning in a light carriage / wagon. The springs on the other hand exert minimal drag..Since your wheels are plastic, you would have to replace the wheels anyway, thus the combined wheel / spring combo offered by DCC Concepts can work out more cost effective in that scenario. Link to comment Share on other sites More sharing options...
Johnboy99 Posted April 1, 2018 Author Share Posted April 1, 2018 Thankyou, I have ordered battry type & some brass wheels and see which I like best,Cheers. Link to comment Share on other sites More sharing options...
