Elliot1982 Posted April 7, 2018 Share Posted April 7, 2018 Hi My TTS was making a funny noise i.e. The sound was playing like the current to the speaker wasn't greatSo opened her up to find the decoder getting extemly hot..... It all went wrong when I was taking her off the sidings to the main track over points, could it have short circuited? And.... . It's broken!?Thanks Link to comment Share on other sites More sharing options...
96RAF Posted April 7, 2018 Share Posted April 7, 2018 A short circuit can damage any decoder.Try a full reset for now by writing value 8 to CV8 if your controller supports that functionality.If no improvement then you could try contacting Hornby to see if you can get it replaced under warranty.Rob Link to comment Share on other sites More sharing options...
Elliot1982 Posted April 7, 2018 Author Share Posted April 7, 2018 Reset but no difference, I think it's been cooked. The problem I've got is I extended the speaker wires so technically I've damaged the original product Link to comment Share on other sites More sharing options...
Chrissaf Posted April 7, 2018 Share Posted April 7, 2018 Since extending the speaker wires is documented in the TTS decoder instructions, and assuming that you have extended them using the method exactly as documented, then I would think it is still covered under Warranty. On the basis that you have adhered to the Hornby provided instructions. Link to comment Share on other sites More sharing options...
Elliot1982 Posted April 7, 2018 Author Share Posted April 7, 2018 Yep, extended from the speaker as described. Best to call them, what do they normally require, sent it back etc? It was purchased via eBay model scenery. Link to comment Share on other sites More sharing options...
