thewurzel Posted April 10, 2018 Share Posted April 10, 2018 Hi Im new to model railways in a way. I used to play with my dads set in the 70's /80's. I now have inherited his set. I have a lot of super 4 track and a very small amount of seris 6 track, small loop with sideing that came with the HST set in the late 70's or early 80's I would like to use the super 4 as i have much more of it and I also have a a turntable that goes with it I am going to get this up and running. building a 8'x 4' layout. I am going to clean and rebuild motors as not much seams to work right now as they have not been used in 30 years.I would like to convert it to a DCC system. Will the older Super 4 track be ok for running DCC?Thanks and any input would be aperciated.Julian Link to comment Share on other sites More sharing options...
jane1707819582 Posted April 10, 2018 Share Posted April 10, 2018 hello julian the track will be fine working on dcc , you will have to convert your loco's to dcc by fitting a decoder to each loco .i think the best thing you can do is get all your loco's running as near perfect as possible , any faults they have on dc will be amplified on dcc.once you have done that you will need to know the stall current of the loco's . ie how much current is taken by each loco in a stallthis will dictate the size of decoder each loco will need ,older kit tends to use more current . Link to comment Share on other sites More sharing options...
trainlover23 Posted April 10, 2018 Share Posted April 10, 2018 Whilst it will work it may not work very well due the fact that the track is steel and will get dirty very quickly Link to comment Share on other sites More sharing options...
thewurzel Posted April 12, 2018 Author Share Posted April 12, 2018 Whilst it will work it may not work very well due the fact that the track is steel and will get dirty very quicklyso what is the best way to keep the older track clean? Link to comment Share on other sites More sharing options...
