SmokeyJ Posted April 12, 2018 Share Posted April 12, 2018 Having fit the sound chip (R8108) into its mounting on the engine, I went to code it up to my 'Select' controller. Expecting seven red flashes for a successful pairing I was surprised to only get 3!I checked that the engine moved around the track - it did, but sadly no sound!Also, during the pairing process the engine was silent - I'm led to believe that the engine should give off a 'whirring' sound - this time it didn't.Can anyone give me some advice, please?Thanks! Link to comment Share on other sites More sharing options...
Howbi Posted April 12, 2018 Share Posted April 12, 2018 Have you pressed the Function button +1 together to turn on the sound?..........there is no whirring sound when programming.........is the loco responding to address 03 on the controller?........HB Link to comment Share on other sites More sharing options...
Chrissaf Posted April 12, 2018 Share Posted April 12, 2018 What version of the firmware does your Select have (the first number to display on screen when Select powers up)?Did you test the TTS on the default 003 address BEFORE trying to change it......if you did, was everything OK including sound?Have you issued a F1 function command to turn the sound on?.EDIT: HB had exactly the same thoughts as me questions wise, as I was typing. Link to comment Share on other sites More sharing options...
