johnpa Posted June 4, 2018 Share Posted June 4, 2018 After fitting R8249 DCC decoder elink flashes and loco moves jerkily in time to the flashes. Loco was working fine as DC before I fitted decoder. Does this suggest that decoder is faulty? I was extremely careful when fitting not to touch any contacts or components. Link to comment Share on other sites More sharing options...
Chrissaf Posted June 4, 2018 Share Posted June 4, 2018 Does this suggest that decoder is faulty?.Possibly. Link to comment Share on other sites More sharing options...
96RAF Posted June 4, 2018 Share Posted June 4, 2018 Can you read the decoder on the programming track or does it bother the eLink there as well. If you can read it try a decoder reset. Rob Link to comment Share on other sites More sharing options...
johnpa Posted June 4, 2018 Author Share Posted June 4, 2018 As the elink keeps flashing and the loco keeps starting and stopping I don't want to leave either running like that - am afraid I'll damage elink or loco. Link to comment Share on other sites More sharing options...
Fishmanoz Posted June 4, 2018 Share Posted June 4, 2018 What loco? If an older type it may be overloading the decoder, in which case you’ll need a 1 Amp type instead. But try a replacement in any case. Unlikely it is overloading the eLink unless faulty. Link to comment Share on other sites More sharing options...
96RAF Posted June 5, 2018 Share Posted June 5, 2018 The reason I said on the programming track is because the current is limited to prevent damage to any of the kit due to a fault.Rob Link to comment Share on other sites More sharing options...
