peter _murray Posted July 29, 2018 Share Posted July 29, 2018 I have two class 66 locks fitted with TTS. I am using an elink control system. When the sound green button is activated the loco goes through its start up sound sequence well. The loco will respond to other command (horn, compressor etc.) However, when given a command to move it will go through the correct sound sequence including brake release then as it starts to move it will stall. The sound stops then goes through the start up sequence again. With perseverance I can get them running and they run just fine, following all commands as directed. I have not altered any CV values other than 29 to remove DCC running, the remaining cv are default values. Any suggestions as to a cure would be helpful. Link to comment Share on other sites More sharing options...
Rog RJ Posted July 29, 2018 Share Posted July 29, 2018 Have you tried cleaning the track and wheels? Link to comment Share on other sites More sharing options...
Chrissaf Posted July 29, 2018 Share Posted July 29, 2018 As Rog indicated. These are classic dirty track / dirty wheels symptoms. Even a layer of dust will affect DCC control. DCC is far less forgiving than analogue DC. Don't forget to clean the back of the wheels, where the pickup wipers rub against. Do not use abrasives for cleaning, except ones purposely designed and marketed for model railway use. Link to comment Share on other sites More sharing options...
Howbi Posted July 29, 2018 Share Posted July 29, 2018 Many have found that changing the motor control algorithm solves this.....change CV150 to a value of 1 (default is 0).......HB Link to comment Share on other sites More sharing options...
peter _murray Posted July 29, 2018 Author Share Posted July 29, 2018 Many have found that changing the motor control algorithm solves this.....change CV150 to a value of 1 (default is 0).......HB Link to comment Share on other sites More sharing options...
peter _murray Posted July 29, 2018 Author Share Posted July 29, 2018 Thank you howbiman. Changed CV150 to 1 and all seems well. Link to comment Share on other sites More sharing options...
Howbi Posted July 29, 2018 Share Posted July 29, 2018 Excellent, thanks for the feedback..........HB Link to comment Share on other sites More sharing options...
