The son of Triangman Posted August 21, 2018 Share Posted August 21, 2018 Does anyone here protect their decoders from an overload? I use a solder in axial in line quick blow fuse rated a little below the max current rating the decoder can draw, the fuse will blow before the decoder does every time if there is an issue. Link to comment Share on other sites More sharing options...
96RAF Posted August 21, 2018 Share Posted August 21, 2018 I have blown decoders at times, but usually by overloading the function outputs or shorting the sound amp. The motor output being self protecting. I have some quick-blow fuses that I bought for a dimmable standard lamp that I may try. Rob Link to comment Share on other sites More sharing options...
The son of Triangman Posted August 21, 2018 Author Share Posted August 21, 2018 Worth a go Rob, I find if you use ones that fast/quick blow at less than the decoder max current it helps. It might be worth protecting the function outputs as well. Link to comment Share on other sites More sharing options...
96RAF Posted August 21, 2018 Share Posted August 21, 2018 BEJForum guidelines please note...No profanity or foul language. This includes using stars (*) or other characters instead of letters. Any un-called for language will be removed and repeated offences will be punished.If you would like to suitably amend/resubmit your post I will hide the one above.Rob Link to comment Share on other sites More sharing options...
BagEndJct Posted August 23, 2018 Share Posted August 23, 2018 (Sorry! I have edited the original post). Not directly relevant but, having blown a number of decoders in my early days of DCC, I now always, always turn off the power to the track when placing locos or re-railing them after derailments. (Hope I'm not stating the obvious here?). To facilitate this, to save my having to scramble around behind the board to turn off power, I use a spare remote controlled power socket into which my Elink power supply is plugged. Link to comment Share on other sites More sharing options...
