happy chap Posted September 9, 2018 Share Posted September 9, 2018 I have a hornby pendolino on select 15-30-03 that goes forword but not in reverse ,if i physicaly turn the loco around it will run.It seems like brake is on when trying to go in reverse.It was running great for months.then suddenly plays up.help appreciatedAny ideas whats happening Link to comment Share on other sites More sharing options...
96RAF Posted September 9, 2018 Share Posted September 9, 2018 Factory fitted decoder or did you fit it and if so which one.When you say it runs when turned round do you mean it then runs both ways or it still only runs forwards.Rob Link to comment Share on other sites More sharing options...
happy chap Posted September 10, 2018 Author Share Posted September 10, 2018 it was a factory fitted decoder,and it still only runs one way when turned around ,all track is nickel and there are no points . Link to comment Share on other sites More sharing options...
2e0dtoeric Posted September 10, 2018 Share Posted September 10, 2018 When in reverse, can you hear the electric motor whizzing?If you can, it may be that it has become dislodged from it's mountng bracket, so the worm gear is pushing itself out of engagement in that direction, but going forwards it doesn't.If you can't do it yourself, take the motor unit back to the shop and ask them to check it for you. It may still be under guarantee, you don't say how long you've had it. Link to comment Share on other sites More sharing options...
happy chap Posted September 10, 2018 Author Share Posted September 10, 2018 the motor runs when i slightly lift it up ,when i put wire direct to wheels motor runs forword and reverse but when on track it judders in forword and comes off track Link to comment Share on other sites More sharing options...
2e0dtoeric Posted September 10, 2018 Share Posted September 10, 2018 You are now describing a totally different problem!So - which is it - the loco won't move in one direction - or it goes in jerks and derails?If you give duff information , you get duff advice! 😛 Link to comment Share on other sites More sharing options...
happy chap Posted September 10, 2018 Author Share Posted September 10, 2018 sorry for confusion ,but thats what was happening ,first it would not go forword,then it attempted to move in jerks and came off rails now gremlins have dissapeared it runs in reverse fine but forword its still running but jerky.Hopefully its sorted itself out.Thanks for your time 😀 Link to comment Share on other sites More sharing options...
