jodel Posted October 4, 2018 Share Posted October 4, 2018 Hi all contributors,I use two DCC central : 1. Railmaster with elink2. DR5000 digikeijs with Traincontrolleri noticed that the adress of my cobalt digital IP for my turnouts, are shifted by 4 poistion with RM, compared with DR5000. Of course it is not a problem if you work only with the same DCC central, for programming the Cobalt and using it.In my case i had to program my cobalt adresse from number 1 with DR5000, and i report the adress on RM layout from number 5. and it works fine.Do some contributor on this forum noticed the same issue ? i knew that the same problem exists with the Roco centrals wich are not full compliant with standard DCC. i noticed it on lay out of my modeling club in using roco mutimaus. But for RM i find it strange..thanks for your replies.jodel Link to comment Share on other sites More sharing options...
96RAF Posted October 5, 2018 Share Posted October 5, 2018 There was an anomaly with Hornby kit in that points addressing was 3 off from ‘standard’. I.e. select point 1 and point 4 fired. This led to introduction of a Standard and Classic mode for the Elite controller. RM uses the Elite in Standard protocol, which is likely also the norm for eLink. I also use Rocrail and the same 3-offset problem was seen in the early days of using Hornby kit and an adjustment was made in the code to cater for it, i.e. you can now tick a box to use either protocol. It may be that your 2 controllers are seeing the same problem.Rob Link to comment Share on other sites More sharing options...
