barry_gaskin Posted October 6, 2018 Share Posted October 6, 2018 Hi my TTS decoder keeps resetting when I press a Function button like a whistle or the coal shoveling ,I have rigged it up to set It with a digitrax Zephyr Xtra and A can Motor to set it up before fitting it, I tried resseting it with CV 8 and it still dose it any idea why the motor comes to a stop and the decoder restarts with the steam let off sounds you get at the beginning and the motor restarts and it starts chuffing again Link to comment Share on other sites More sharing options...
96RAF Posted October 6, 2018 Share Posted October 6, 2018 I have seen a similar fault when I used my track after a long time of inactivity. The sound was OK when standing but as soon as throttle was applied it did the same as yours is doing. After giving the track and locos a good clean all was well. I would also check your loco pickups are good whislt you are cleaning the wheels Rob Link to comment Share on other sites More sharing options...
Chrissaf Posted October 6, 2018 Share Posted October 6, 2018 See also:https://www.hornby.com/uk-en/forum/hornby-tts-decoders-reported-problems/This thread discusses issues using TTS with NON Hornby controllers. Link to comment Share on other sites More sharing options...
barry_gaskin Posted October 6, 2018 Author Share Posted October 6, 2018 Hi I have now cured this issue by trying out my old Lenz controller instead of the Digitrax it seems the Decoder did not like the digitrax for some reason Link to comment Share on other sites More sharing options...
