dougal88 Posted October 8, 2018 Share Posted October 8, 2018 Hi, I`ve just purchased 6704 on e bay, allegedly new and untested and fitted with the relevant tts decoder. when running forward all 3 headlights and 2 red taillights are on. running in opposite direction 2 red taillights are on but only the top headllight of the 3 works, any ideas on this please?? Link to comment Share on other sites More sharing options...
96RAF Posted October 9, 2018 Share Posted October 9, 2018 Hornby often use spring contacts between the body and chassis for the lights. These can be a bit hit and miss.Pull the service sheet for your loco and see if that is how your lights are rigged.Rob Link to comment Share on other sites More sharing options...
96RAF Posted October 9, 2018 Share Posted October 9, 2018 Service sheets for the Hornby Class 67 are 290 and 383.The lights are different on each so you need to look to see which yours is. One is contacts and the other is hard wired.Rob Link to comment Share on other sites More sharing options...
dougal88 Posted October 10, 2018 Author Share Posted October 10, 2018 Hi Rob, The problem end lights did all flicker on once when running so I`m assuming it`s the spring clips as you suggested.Many thanks for that information,just a matter of investigation now.RegardsDougal. Link to comment Share on other sites More sharing options...
