colin142 Posted November 13, 2018 Share Posted November 13, 2018 After I had fitted a Hornby DDC decoder into the tender of a Hornby Drummond class 700, I programed it with my Elite controller. When I tried to run the loco on the main track the Elite showed a short. I found that the decoder was shorting, as the room in the tender was limited even after I had insulated it. After a bid of juggling around I managed to fix the problem. When I tried to run the loco again it showed a fault so I tried to re-program the decoder with no luck, but when I programmed it with a different address it worked and has been fine.Now if I try to program another decoder now using the original address that was given to the Class 700 it comes up with an error, but I can use other addresses with no problems. Any ideas? Link to comment Share on other sites More sharing options...
96RAF Posted November 13, 2018 Share Posted November 13, 2018 I would reset the Elite via the Menu button > Unit > Reset first, then try that address again. If its still flaky then reset the decoder (write value 8 to CV 8). There has been some odd stuff noted by folk when an address is divisible by a certain number (4 or 5 ??) it plays up. Absolutely no reason why it should happen.Rob Link to comment Share on other sites More sharing options...
colin142 Posted November 13, 2018 Author Share Posted November 13, 2018 Thank you, I'll give it a go. Link to comment Share on other sites More sharing options...
