Harbottle 1937 Posted November 19, 2018 Share Posted November 19, 2018 Hi anyone fitted the Sleuth steam generator to a DCC loco, and have you had any problems,such as heater coil burning out when running dry of steam oil. Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 19, 2018 Share Posted November 19, 2018 Try a forum search on smoke generator to access the many threads where this has been previously covered including the generators that fall within the power limitations of decoder function wire outputs. Yes ,you will burn it out if you run out of oil but one advantage of DCC connection is you can turn it off easily. Link to comment Share on other sites More sharing options...
Harbottle 1937 Posted November 19, 2018 Author Share Posted November 19, 2018 I had one in I think around 1960 and the coil burnt out in no time at all I think it was Triang Princess class Link to comment Share on other sites More sharing options...
