Johnboy99 Posted November 24, 2018 Share Posted November 24, 2018 Morning All , I have a dapol class 52 active drive with sound but the station ambiance is ver low do I alter it on the program track or the main track the cv setting I mean it is F15 cv 556' thanks also I have brought a new Hornby flying Scotsman with sound fitted from hornby store but it has in the box a spare axel with two wheeles attached to it please what is this for a front bogie, Thanks. Link to comment Share on other sites More sharing options...
Chrissaf Posted November 24, 2018 Share Posted November 24, 2018 The answer to your 'what track do I modify CV556 on' will depend upon what controller you are using, and you haven't said..If you have RailMaster & eLink then you can ONLY do it on a 'Prog' track.If you have an Elite then you can do it on either the 'Prog' track output (direct mode) or on the 'Track' output using 'Operate Mode' - read the Elite manual for how to use 'Operate Mode' sometimes referred to as POM (Programming On Main).If you have a Select, then you can't adjust this CV at all..With regard the spare axle with two wheels. The most likely answer (can't be 100% sure because you haven't stated the model R number) is that they are used to replace the flangeless wheels that are located under the cab when the model is not going to be run on a layout but displayed statically in a cabinet instead. If you fit these spare (flanged) wheels on the loco to use on your track, then the flanges will catch the rails on curves & points and the loco WILL derail..EDIT: Looking at your posting history. I see that you may have a Prodigy controller. This controller supports POM (see POM comment in Elite bullet point above). Read the Prodigy manual for how to use POM. Link to comment Share on other sites More sharing options...
Johnboy99 Posted November 24, 2018 Author Share Posted November 24, 2018 Thanks Chris . Link to comment Share on other sites More sharing options...
