Clink Posted December 12, 2018 Share Posted December 12, 2018 Hello allIm clink and new to dcc....I have hornby dcc select controllers and have just purchased mallard dcc with tts sound...will my controllers work with my loco.Thanks Link to comment Share on other sites More sharing options...
96RAF Posted December 12, 2018 Share Posted December 12, 2018 Yes - but depending upon the firmware revision state of your Select depends upon how many sound functions you can operate. When you power up your Select note the three pairs of numbers seen and tell us the first set. You say Selects. Just be aware you can only connect one DCC controller to a track at the same time. Rob Link to comment Share on other sites More sharing options...
Urbarm8 Posted December 14, 2018 Share Posted December 14, 2018 Yes it will Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 14, 2018 Share Posted December 14, 2018 Urbarm, will only do so with all sound functions, as Rob says, if at firmware v1.5, meaning the first pair of digits appearing at startup are 15. Link to comment Share on other sites More sharing options...
