Boognish Posted January 15, 2019 Share Posted January 15, 2019 Having trouble finding the digital throttle extension cables,does anyone know if other cables can be used? Link to comment Share on other sites More sharing options...
woodcote Posted January 15, 2019 Share Posted January 15, 2019 I’ve used 2.5mm stereo jack to 2.5mm in-line socket cables. They come in various cable lengths. The only issue is that the plastic covering of the jack plug is usually too thick to fit properly on the powerbase. I shaved down the diameter of the plastic covering, others open up the hole in the plastic case of the powerbase. The extra cable length certainly helps if you have a full grid of six drivers. Link to comment Share on other sites More sharing options...
Boognish Posted January 15, 2019 Author Share Posted January 15, 2019 I’ve used 2.5mm stereo jack to 2.5mm in-line socket cables. They come in various cable lengths. The only issue is that the plastic covering of the jack plug is usually too thick to fit properly on the powerbase. I shaved down the diameter of the plastic covering, others open up the hole in the plastic case of the powerbase. The extra cable length certainly helps if you have a full grid of six drivers.And all fuctions work ok?the brake and digital lane switch? Link to comment Share on other sites More sharing options...
woodcote Posted January 15, 2019 Share Posted January 15, 2019 The controllers function as usual. I believe the C7057 cable is a mono cable, but a stereo extention carries mono signals perfectly well. Link to comment Share on other sites More sharing options...
Andy P. Posted January 15, 2019 Share Posted January 15, 2019 Using stereo ove rmon means if you happen to get a powerbase with brakes enable the controllers will use them as well.If you use mono no brakes will work. Link to comment Share on other sites More sharing options...
