Mastmonkey Posted January 18, 2019 Share Posted January 18, 2019 I am new to the hobby and recently purchased a used Hornsby class 67 loco at an exhibition which was DCC fitted. Using a Guagemaster Prodigy Advance I introduced it to my track and sound immediately went through a start up. However since I reprogrammed a new loco address I cannot get any sound at all. The loco runs in both directions, the running lights work and the acceleration and deceleration works fine . I suspected that the sound card might be faulty and to rule this out purchased a new Hornsby class 67 sound card. However with this card fitted the loco will not run and there is still no sound . Can anyone advise? Being new to the hobby I am on a very fast learning curve and have spent hours trawling Youtube for instruction. The loco now has the old card fitted and is running without sound. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 18, 2019 Share Posted January 18, 2019 It is very rare for sound to default to 'on'. The likelihood is (being a used second-hand purchase) that the sound had been left 'on', and the loco just physically removed from power with the sound still playing prior to it being sold to you. Such that somehow the 'sound on' command had been remembered and acted upon when you placed the loco on your live track, which in itself would be unusual..It is more normal for sound to be 'off' when initially powered up on a DCC track. You then call up the 'loco address' on the DCC controller you are using and you send a function F1 command to turn the sound 'on'..What happens when you send an F1 command?.TIP: As this is your first post, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 18, 2019 Share Posted January 18, 2019 When you fitted the new sound decoder (not card), did you try to run the loco first on the default 03 address rather the address the original decoder was set to? The address is held in the decoder, not your controller, and all new decoders come on the default 03 address. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 18, 2019 Share Posted January 18, 2019 Was about to put the same comment! All new DCC decoders are set to default 03 address. Link to comment Share on other sites More sharing options...
96RAF Posted January 19, 2019 Share Posted January 19, 2019 Don’t believe all you see on U-tube instructional videos, in my opinion a great number of them are absolute rubbish, poorly produced and often inaccurate. The only way to know if they are of any use is to know the subject already and then you don’t need them.Rob. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 19, 2019 Share Posted January 19, 2019 I agree, I have watched some YouTubes where I just want to scream at the screen and club the presenter with a baseball bat for the totally incorrect and misleading 'so called expert advice' they give......not..Particularly on the electrical side of things which is my forte. Link to comment Share on other sites More sharing options...
morairamike Posted January 19, 2019 Share Posted January 19, 2019 You could read the CV info back with your controller and see what it thinks it is. Your instruction manual will tell you how to do this. That will confirm the address and also what CV 29 is set up for. Link to comment Share on other sites More sharing options...
Mastmonkey Posted January 19, 2019 Author Share Posted January 19, 2019 Thanks everyone for your helpful advice. It would appear that the old sound decoder is not working but when as suggested I tried the default 03 address on the new decoder I was able to get sound. The reason that the loco would not move was that the SV and DC values were set to zero. When I finally heard the loco start up release its brakes and start to move I had a very silly grin on my face. Once again thanks to everyone for taking the time to help. Link to comment Share on other sites More sharing options...
