Derek 19B Posted February 6, 2019 Share Posted February 6, 2019 Will the Lights in the Pullman coaches and the observation car work on a DCC layout without any re-wiring?Derek19b Link to comment Share on other sites More sharing options...
Rog RJ Posted February 6, 2019 Share Posted February 6, 2019 Yes I believe so but they will always be on while the layout is powered up. Link to comment Share on other sites More sharing options...
Chrissaf Posted February 6, 2019 Share Posted February 6, 2019 Totally compatible with DCC (I have some). And yes, as Rog says, they will be on permanently. Link to comment Share on other sites More sharing options...
Derek 19B Posted February 6, 2019 Author Share Posted February 6, 2019 Thanks for the replys , can soon isolate the track to switch the lights off. Looks like DCC layout coming up. ThanksDerek 19b Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 6, 2019 Share Posted February 6, 2019 Derek, if you isolate the track, there will be no power to run the train. So, apart from having it in something like a siding you can isolate by throwing the point away from the siding, no you can’t. Usually with DCC, you try to make the entire layout live all of the time via a DCC bus or initially using DCC point clips. But you can leave the clips off siding points if you only want to run trains in and out of the siding and not move around on the siding by itself. Link to comment Share on other sites More sharing options...
