Hornby Customer Care Posted February 7, 2012 Share Posted February 7, 2012 R8236 - This is a standard RJ12 Cable with 3 twisted pairs in the standard RJ12 configuration with a 6 conductor connector. This cable is only used in conjunction with the Booster unit.R8266 - This is actually an RJ11 Cable with 2 twisted pairs in a non standard configuration with a 4 conductor connector. This cable is only used in conjunction with the Walkabout unit.**However they both use the same plug socket shell. Link to comment Share on other sites More sharing options...
96RAF Posted February 8, 2012 Share Posted February 8, 2012 This could be a disaster waiting to happen as the smaller plug can be plugged into the same socket as the larger one if aligned carefully, but you say they both have the same socket shell.I notice RJ45 compounds the error with 8 pins, that you can plug either an RJ11 or RJ12 into.Why didn't you at least use different coloured cable or hang a sensible label on them, such as 'ONLY TO BE USED WITH ...'.Is there any difference in length to give us a clue as in your shop illustrations they both look to be the same length, although the booster cable is tagged at 3m, the other has no length quoted.Apart from looking at how many pins they have is there a problem plugging the walkabout cable into a booster (and what ever the other end fits) - i.e. will it blow one or both ends of the kit...Rob Link to comment Share on other sites More sharing options...
Hornby Customer Care Posted February 9, 2012 Author Share Posted February 9, 2012 These wires if used incorerectly will not harm your equipement; they will not work corretly. Link to comment Share on other sites More sharing options...
96RAF Posted February 9, 2012 Share Posted February 9, 2012 Thank you HCCCould you please tell me how long each variant is such that I can positively identify and label the one I have.@all - please see this thread which also explains the wiring more but adds to the confusion with ethernet cables...http://forum.rocrail.net/viewtopic.php?t=3823 Rob Link to comment Share on other sites More sharing options...
