ColinB Posted April 5, 2019 Share Posted April 5, 2019 I have just purchased a Hornby Class 66 (have to thanks James May for that sale Hornby), I would like to fit lights to it. I know how to wire it to DCC, I would just like to know if anyone else has done it. I am more interested in the mechanical aspects, like which ones to simulate, cab lights are easy, it is the headlight and tail light that I am more interested in. Link to comment Share on other sites More sharing options...
96RAF Posted April 5, 2019 Share Posted April 5, 2019 Just stay within TTS decoder function output current limits as they are not self protecting. Link to comment Share on other sites More sharing options...
ColinB Posted April 13, 2019 Author Share Posted April 13, 2019 I finally completed this. I only added cab lighting and a headlight above the driver. I used 2mm white led for the headlight. When you drive through the existing headlight the plastic molding falls off, I had assumed it was part of the main molding. Anyway using 2mm tower leds, it gives a great effect. The lights on the buffer beam I left. I was going to use DCC Concepts micro Leds but I found that it was too near the joint with the chassis, so I left them alone. Link to comment Share on other sites More sharing options...
