james john_gudgeon Posted May 17, 2019 Share Posted May 17, 2019 I have just received the new Class 50 DCC sound decoder. I have fitted to Hornby class 50 locomotive R2434 50149 defiance. I am using a Hornby Elite DCC Controller. When moving off from stationary the locomotive judders and does not run normally until more power is applied. The same happens when the locomotive slows down to stop. The locomotive was previously fitted with a lenz LE1035E recorder and ran perfectly. I have refitted the lenz decoder and Locomotive again runs perfectly. Have others found this problem with TTS sound decoders and if so can you please advise the solution. Regards Jim Link to comment Share on other sites More sharing options...
Howbi Posted May 17, 2019 Share Posted May 17, 2019 This is a common problem and is usually easily resolved by changing CV150 to a value of 1 (the default is 0). This is the alternative motor algorithm and is described more fully in the instruction manual with other adjustments you may wish to try.............HB Link to comment Share on other sites More sharing options...
jane1707819582 Posted May 17, 2019 Share Posted May 17, 2019 have a look on the instruction sheet , there a some cv's which alter the motor control ,cv 150 to 1 usually helps then there are other cv's to adjust does the class 50 have a flywheel on the motor this can effect the cv settings Link to comment Share on other sites More sharing options...
Chrissaf Posted May 17, 2019 Share Posted May 17, 2019 TIP: As this is your very first post, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button. Link to comment Share on other sites More sharing options...
james john_gudgeon Posted May 17, 2019 Author Share Posted May 17, 2019 Thank you for the advice. The class 50 does have a drive to the fan. I will try the changes to the CVs as you have advised Link to comment Share on other sites More sharing options...
james john_gudgeon Posted May 18, 2019 Author Share Posted May 18, 2019 HelloI have changed CV150 to value of 1 and it solved the problem. Thank you Link to comment Share on other sites More sharing options...
ph54 Posted May 25, 2019 Share Posted May 25, 2019 I have the same problem and thanks for the info, now can anyone explain why with my Class 50 I have to plug the decoder in backwards. i.e Slate is pin 1 when Orange is normally pin 1. Link to comment Share on other sites More sharing options...
Rog RJ Posted May 25, 2019 Share Posted May 25, 2019 Some class 50 models are known to be incorrectly wired. What particular model have you got? A few other random models also have wiring problems. Link to comment Share on other sites More sharing options...
Phil_Spiegel. Posted May 25, 2019 Share Posted May 25, 2019 I have 2 Class 50s fitted with TTS, so far, and one previously with a Loksound.As observed above - the loksound provides a smooth start by default, but both TTS versions have the very jerky start. Yes they have fans - but these make no difference. Yes they have flywheels.I have tried changing to the 'other algorithm' =1 which wa slightly better --- I may look at the values in a Class 31 to see how different they are to help me get it right ! - the 31's do not show the problem.One of my 50s was also a version* which had a board and LED lights wired for common cathode .... my solution was to replace the PCB and LED boards completely and use veroboard, and warm white instead of yellow LEDs while I was changing them/ *Socket marked 180degrees from other 50's possibly part number 1621 X001R6 w400 94V-0. Luckily the TTS decoder had survived being plugged into it, as marked - the controller detected a short and protected it. (It had previously had an earty ZTC decoder installed) Loco was 50035 blue large logo Ark Royal Link to comment Share on other sites More sharing options...
richard_croft Posted May 29, 2019 Share Posted May 29, 2019 I fitted one tonight and had the same issues. I changed CV 150 to 1 as sugessed previously and it works much better. I also changed CV 3 to 60 and CV 4 to 30 to slow down the acelleration and decelleration. Richard Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 30, 2019 Share Posted May 30, 2019 This topic is only a page long and already has the OP asked, answered and successful, then 2 hijacks, the first possibly explained but unanswered and the second only comments somewhat consistent with OP problem (then change the motor algorithm must be the most common answer to TTS problems). PH, as you do seem to have a wiring fault, many of which have been reported previously, suggest you contact HCC by phone with a view to replacement or rewire. And next time ,I suggest you will get more advice quicker by starting your own thread instead of hiding your post at the bottom of a different problem. Link to comment Share on other sites More sharing options...
