ptr159 Posted May 19, 2019 Share Posted May 19, 2019 I have seen a four lane micro scalextric track on youtube but where do I buy the smaller radius bends from ? Link to comment Share on other sites More sharing options...
Andy P. Posted May 20, 2019 Share Posted May 20, 2019 Could you link the video please?I may be wrong but I don't recall a 4-lane layout possibility... Link to comment Share on other sites More sharing options...
woodcote Posted May 22, 2019 Share Posted May 22, 2019 Hi ptr159 - welcome to the forum! All the Micro Scalextric systems - Scalextric Micro MR1 (1994-6), Micro Scalextric (1995-2019) and the new Micro Scalextric (summer 2019 onwards) - have only one radius size of standard curve. That means it is not possible to build a track with four lanes running side-by-side around the circuit. Other 1/64 scale systems that do offer this feature include Tomy AFX and Tyco/Mattel. Micro Scalextric cars will run on these track systems. However, there are a few ways to build Micro Scalextric into a four lane layout. 1) The 1995-2019 track system does have a hairpin turn. This fits inside the standard curve with a significant gap, so doesn’t look great. It is also a 180-degree corner, so track design is pretty limited - but could be combined with the second option... 2) You can use the standard curves on both lanes - there will be gaps and you’ll need to use different length straights to line everything up, but you will get a four-lane track. Designing with a computer program (eg Ultimate Racer) will make things easier! 3) Build a ‘mirror’ or ‘butterfly’ track. This is where you run a long four lane straight (the body of the butterfly) with the rest of the circuit going off opposite directions - identical, but a mirror image (the wings of the butterfly). I’ve seen this layout used and it works nicely! The new track system will be released next month (June 2019) with a My First Scalextric set. Currently there is only one corner radius, but Scalextric are keen to develop the system - so more corners are not out of the question at some point down the line. I certainly have my fingers crossed... Link to comment Share on other sites More sharing options...
