wizzie Posted July 1, 2019 Share Posted July 1, 2019 Hi guys, is possible to use Railmaster with hand operated points as I've not setup electric points as yet?ThanksWizzie Link to comment Share on other sites More sharing options...
96RAF Posted July 1, 2019 Share Posted July 1, 2019 WelcomeYou can run your DCC locos with RM, but if you want your trackplan routes to match your manually set points then you have to change the points on screen as well, even though they are phantoms. If you want to set them to an indicative route at startup so you can set that route by hand then that is also possible. Link to comment Share on other sites More sharing options...
wizzie Posted July 1, 2019 Author Share Posted July 1, 2019 Thanks for that, will try the evaluation and see if its easy or not. Link to comment Share on other sites More sharing options...
