Wincanton Central Posted July 5, 2019 Share Posted July 5, 2019 I've trawled the forums but haven't found this issue, so sincere apologies to all if it's already been covered somewhere.I use an NCE Power Pro. When running several sound equipped locos, including a batch of Hornby Class 31s (super detail version, retro fitted with TTS), every now and again, and out of the blue, one or more of the TTS locos will randomly start moving before any selection of that loco at all, leading to a hasty selection of the moving loco and press of the stop button, or a district shutdown when unnoticed it's moved off and run into adverse points or derailed.Anyone else had this problem, and has anyone a solution ? Link to comment Share on other sites More sharing options...
westernwill Posted July 5, 2019 Share Posted July 5, 2019 Do you have DC running set off ? Link to comment Share on other sites More sharing options...
Chrissaf Posted July 5, 2019 Share Posted July 5, 2019 Also, (since the locos are TTS) double check to ensure that all suppression capacitors have been removed from any Hornby power track / clip products that you might be using. I have just this evening written a reply that documents how these capacitors can affect the operation of TTS loco decoders..My other reply can be viewed here:https://www.hornby.com/uk-en/forum/dcc-power-track-v-ordinary-dc-power-connecting-track/?p=1 Link to comment Share on other sites More sharing options...
