chelseafc Posted July 16, 2019 Share Posted July 16, 2019 looking to but american syle building from woodland scenics for u.s.a themed track,what scale should i but ? Link to comment Share on other sites More sharing options...
Andy P. Posted July 16, 2019 Share Posted July 16, 2019 It depends on which system you own.If you own the most common Scalextric set it is 1/32 scale (cars are about the size of an adult hand).Some common model scale are also 1/35 which is slightly small but depending on the building and setting you can probably still make it work. I have seen a few 1/30 scale buidlings which would be too big but again, might still able to be made to work (an outhouse/port-potty for example).If you have the smaller Micro Scalextric they are approx 1/64 scale (cars are about the size of die cast "HotWheels/Matchbox" cars). This is sometimes call "H0" or "HO" but there is no real consensus as to what the correct scale is. It could range from 1/60 all the way down to 1/87. This size of track is very common in the US (Tyso, AFX, LifeLike etc...). This is also the common size for many train sets (including the Hornby brand) and there are LOTS of buildings available... Link to comment Share on other sites More sharing options...
chelseafc Posted July 16, 2019 Author Share Posted July 16, 2019 1.32 is the Scalextric I am working with Link to comment Share on other sites More sharing options...
Andy P. Posted July 16, 2019 Share Posted July 16, 2019 So O gauge would be too small (unless you are going for forced perspective and putting smaller buildings "in the distance"https://en.wikipedia.org/wiki/O_scale#Scale_and_gaugeG sacle/gauge is likely to be too big:https://en.wikipedia.org/wiki/G_scaleModel ScalesG = 1:24O = 1:48S = 1:64OO = 1:76.2HO = 1:87N = 1:160Z = 1:220Gague One is official 1/32 scale but I don't see that as a common building scale.Good luck and send us pictures! Link to comment Share on other sites More sharing options...
Andy P. Posted July 16, 2019 Share Posted July 16, 2019 PS: I know that there are companies out there like Slot Track Scenics maybe look there. Link to comment Share on other sites More sharing options...
