96RAF Posted July 22, 2019 Share Posted July 22, 2019 For the interest of those who have one of these handy devices there appears to be a build fault on some of them whereby the NEM651 6-pin socket whilst glued to the board does not have its pins inserted into or soldered to the PCB. Any electrical continuity will be accidental. See here...Top side/media/tinymce_upload/f16c40755ea861ef3ed1aea35de9e87c.jpgUnderside/media/tinymce_upload/f3046e8d5df925d2ec339fb271e74374.jpg Link to comment Share on other sites More sharing options...
oldpottsline. Posted July 22, 2019 Share Posted July 22, 2019 Maybe why they discontinued it and replaced it with 53900. Link to comment Share on other sites More sharing options...
96RAF Posted July 22, 2019 Author Share Posted July 22, 2019 My other one has solder on the underneath holes but the pins still lay flat topside. Easily fixed in either case. As far as I know the only real difference between the two models is the newer one has motor direction leds as well as direction lights leds, so you can check the motor and the lights are ‘facing’ the same way. Link to comment Share on other sites More sharing options...
