baz47 Posted August 16, 2019 Share Posted August 16, 2019 when trying to change chip numbers it wont change remains same number, re-put standard back on as was classic no difference, if I reset to factory settings what will I loose as updated to version1. 4.1. I would like to add that my selects and other elite are working OK Link to comment Share on other sites More sharing options...
Rog RJ Posted August 16, 2019 Share Posted August 16, 2019 You will only lose any loco names that you have entered. The firmware version will not be affected. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted August 16, 2019 Share Posted August 16, 2019 I would like to add that my selects and other elite are working OKI hope you only have ONE controller connected to the track!You can connect Selects to the Elite, to use more controllers at once, but most NOT connect two (or more) to the track! Link to comment Share on other sites More sharing options...
96RAF Posted August 17, 2019 Share Posted August 17, 2019 It is presumed you have the loco being readdressed connected to a programming track on the Elite PROG output. If so try using Reg rather than Direct programming mode as this can be more reliable with some ‘awkward’ decoders. Of course it could be your Elite programming output is dead, a not unknown problem. You may also like to update your Elite to v1.44 As updates simce your version improved support for more decoders. Link to comment Share on other sites More sharing options...
