pk_shot_you Posted September 14, 2019 Share Posted September 14, 2019 I have cut a 180 degree R! inner border in two and added an extentiion piece so we could make a double apex R1 hair-pin.What glue fuses Scalextric border plastic? I have tried CA glue and it just lets go. If anyone has suggestions, I'm all ears.CheersPK Link to comment Share on other sites More sharing options...
woodcote Posted September 14, 2019 Share Posted September 14, 2019 Hi PK - welcome to the forum! I’d try something flexible like Shoe Goo. Good luck! Link to comment Share on other sites More sharing options...
Andy P. Posted September 16, 2019 Share Posted September 16, 2019 You will likely have to sand the contact area a little make sure it is slightly rough.Also use alcohol to degrease it a bit.Show goo (other brands are available) is good because it is flexble and "gives".I know for a fact that hot gun glue will stick (if things are "roughened up" a bit) and you can use alcohol to remove it. Link to comment Share on other sites More sharing options...
