Millsy1707819711 Posted September 18, 2019 Share Posted September 18, 2019 Hello, I recently got a bargiain class 67 in mint condition from ebay. The “Rising Star” to be precise, (67027 I think, off the top of my head). I have watched a few youtube videos on the loco and noticed that the majority of them have both the front and rear (white and red) running lights, whereas mine only has the front running lights (white). They do change based on which direction the loco is going, but I don’t appear to have red lights on mine on the rear.Is this how they were designed or is something wrong with my loco?Kind Regards,Millsy Link to comment Share on other sites More sharing options...
jane1707819582 Posted September 18, 2019 Share Posted September 18, 2019 there are two versions of the class 67 ,one is the 383b ,looking at the explo drawing it may be possible that the contacts on the pcb are not making correctly , give the none working red light end a gentle squeeze to see if that makes a difference . Link to comment Share on other sites More sharing options...
Ruffnut Thorston Posted September 18, 2019 Share Posted September 18, 2019 Just a thought. With some locos, the red tail lights can be turned off, either with small switches, or by a function on DCC, as the tail lights should not be lit when the loco is hauling a train... So maybe they are turned off? Link to comment Share on other sites More sharing options...
Robby_50 Posted September 28, 2019 Share Posted September 28, 2019 Hornby has made 2 completely different versions of the class 67.Version 1 was the ex-Lima model from 2006.This only has the directional 2 white lights on each end fed from a single bulb at each end via light guides. The main difference from the original Lima model is Hornby put a proper 8 pin socket inside the loco.The red marker lights and white headlight above the windscreen are just painted on the body. R2522 67 027 Rising Star is definitely this model, so unfortunately no working red lights or headlight. Ramseys Model Train guide values the secondhand model between £55 and £70 without decoder. I have 3 of these locos in different liveries and they work really well.Version 2 is a complete retool from 2012. This has etched side grills, NEM coupling socket and a full set of working red and white lights at each end. The current Colas liveried model is this version. I'm fairly sure Hornby have not made 67 027 in this version. The Youtube videos are probably mostly of this more recent model. Ramseys values secondhand model at £100 to £130 without decoder ( a bit over-valued I feel ).I have 1 of this model and while it is more detailed, from a couple of feet away it's hard to notice much difference. Link to comment Share on other sites More sharing options...
