mrmetallica Posted October 8, 2019 Share Posted October 8, 2019 ive just converted 2 nissan gtr drift cars to digital race cars. im looking for the guids for the front of the car as they didnt come with the underpan surprisingly where can i find them Link to comment Share on other sites More sharing options...
Andy P. Posted October 8, 2019 Share Posted October 8, 2019 You can search under Help & advice - > Service Sheets and then enter Nissan and you will find the service sheet for the drift cars:https://www.scalextric.com/servicesheets/index/download/id/203/Orhttps://www.scalextric.com/servicesheets/index/download/id/271/Drift cars use a 360° guide blade C8330 which should still be usable on a digital layout but will cause problems if the car turns around... Link to comment Share on other sites More sharing options...
mrmetallica Posted October 8, 2019 Author Share Posted October 8, 2019 i want car guides for the race version ive got them for the drift car but want to change the so the car carnt turn around Link to comment Share on other sites More sharing options...
woodcote Posted October 8, 2019 Share Posted October 8, 2019 Hi mrmetallica - welcome to the forum! This is the standard guide assembly for most modern Scalextric cars: https://www.scalextric.com/uk-en/round-guide-blade-4-braid-plates-1-screw.html If the non-drift Nissan GTR underpan is Digital Plug Ready (DPR) - which I am 99.9% sure it is - that's the guide you need. Link to comment Share on other sites More sharing options...
Andy P. Posted October 9, 2019 Share Posted October 9, 2019 I could be wrong but I don't think you can swap a standard guide into a drift guide hole straight out of the box.The wires are not connected in the same way.If you search the service sheets as mentioned there are drift and non drift Nissans mentioned and it should be clear if the underpan can be swapped out or not. Link to comment Share on other sites More sharing options...
mrmetallica Posted October 9, 2019 Author Share Posted October 9, 2019 I could be wrong but I don't think you can swap a standard guide into a drift guide hole straight out of the box.The wires are not connected in the same way.If you search the service sheets as mentioned there are drift and non drift Nissans mentioned and it should be clear if the underpan can be swapped out or not.your not wrong you carnt the drift ones bolt onto circuler metal rings.ive swapped the under pan for a race type but wasnt sure wich blade guids i need Link to comment Share on other sites More sharing options...
mrmetallica Posted October 9, 2019 Author Share Posted October 9, 2019 Hi mrmetallica - welcome to the forum! This is the standard guide assembly for most modern Scalextric cars: https://www.scalextric.com/uk-en/round-guide-blade-4-braid-plates-1-screw.html If the non-drift Nissan GTR underpan is Digital Plug Ready (DPR) - which I am 99.9% sure it is - that's the guide you need.thanks for the welcome and for the link to the guides very help full and the underpan is digital ready. Link to comment Share on other sites More sharing options...
mrmetallica Posted October 9, 2019 Author Share Posted October 9, 2019 You can search under Help & advice - > Service Sheets and then enter Nissan and you will find the service sheet for the drift cars:https://www.scalextric.com/servicesheets/index/download/id/203/Orhttps://www.scalextric.com/servicesheets/index/download/id/271/Drift cars use a 360° guide blade C8330 which should still be usable on a digital layout but will cause problems if the car turns around...ive done a search but comes up with nothing Link to comment Share on other sites More sharing options...
Andy P. Posted October 10, 2019 Share Posted October 10, 2019 There is a search on the Service Sheet page:https://www.scalextric.com/uk-en/downloads/scalextric-service-sheetsYOu have to click on View and when you type in Nissan you get 5 hits... Link to comment Share on other sites More sharing options...
mrmetallica Posted October 10, 2019 Author Share Posted October 10, 2019 There is a search on the Service Sheet page:https://www.scalextric.com/uk-en/downloads/scalextric-service-sheetsYOu have to click on View and when you type in Nissan you get 5 hits...thank you done that found the car but when i search for parts it show no results is it because they dont have any or im doing it wrong Link to comment Share on other sites More sharing options...
Andy P. Posted October 10, 2019 Share Posted October 10, 2019 Try google so you can find a local source.. Link to comment Share on other sites More sharing options...
mrmetallica Posted October 10, 2019 Author Share Posted October 10, 2019 Try google so you can find a local source..trust me there is nothing local to me. all the hobby shops etc have shut down around where i live.ive found the bits now so thank you all for the help Link to comment Share on other sites More sharing options...
