St1ngr4y Posted October 23, 2019 Author Share Posted October 23, 2019 That sounds like the controller has stopped responding to the messages being sent by the pc. Are you using Elite or eLink? What versions of firmware are in use in the controller(s) and what baud rates are being used between the pc and controller(s)? Edit: After thought - you should be running TTSS5 with Railmaster not loaded. Is this the case? Ray Link to comment Share on other sites More sharing options...
AncientMariner Posted October 23, 2019 Share Posted October 23, 2019 That sounds like the controller has stopped responding to the messages being sent by the pc. Are you using Elite or eLink? What versions of firmware are in use in the controller(s) and what baud rates are being used between the pc and controller(s)? Edit: After thought - you should be running TTSS5 with Railmaster not loaded. Is this the case? RayI'm using the program that I put in the Railmaster folder. Railmaster is not running. Here is the connection data: COM4 9600,N,8,1 Elite v1.44 Link to comment Share on other sites More sharing options...
St1ngr4y Posted October 23, 2019 Author Share Posted October 23, 2019 Hi, 19200 is the recommended baud rate for an Elite. If you go into Device Manager and find the entry for COM4.../media/tinymce_upload/3dcacd937ec0305e538ac96f7bcc05c1.pngMy pc uses COM3 for my Elite and COM5 for the eLink. Give this a try to see if it makes any difference. Ray Link to comment Share on other sites More sharing options...
AncientMariner Posted October 24, 2019 Share Posted October 24, 2019 Hi, 19200 is the recommended baud rate for an Elite. If you go into Device Manager and find the entry for COM4.../media/tinymce_upload/3dcacd937ec0305e538ac96f7bcc05c1.pngMy pc uses COM3 for my Elite and COM5 for the eLink. Give this a try to see if it makes any difference. RayHi Ray, Changed the baud rate. I have partial success: entry 0055A with correct data is now in the text file but not 0055B. I also have 0065A/B but I'm not sure that I tried to save those entries correctly. I'm not absolutely sure that the changed baud rate was the key, since I tried a save with the old rate as well. Link to comment Share on other sites More sharing options...
AncientMariner Posted October 25, 2019 Share Posted October 25, 2019 Hi Ray, I think I know what is happening here. I've changed the permissions on the folders. I can now write to the text file lines 0055A/B and 0065A/B, and the text shows up in the program as it should. If I save from the program and exit the B line is deleted. If there is a 0065 line then that B line goes, if not the 0055B goes. I have tested this with the program in the Railmaster folder, and in its own. It seems to work equally well in either, but the effect on the associated text file is the same. I can't work out why though! Is thtis any help to you? AM Link to comment Share on other sites More sharing options...
Chrissaf Posted October 25, 2019 Share Posted October 25, 2019 AM,You might benefit from reading TIPs 2 & 3 in my 'How To' TIPs page. TIPs 2 & 3 relate to extracting your own added text from the buff quote box. At present with your posts, it is very difficult for a reader to see what is a re-quote and what is new text..https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
St1ngr4y Posted October 25, 2019 Author Share Posted October 25, 2019 @AncientMariner While I contemplate your text file problem, did you resolve the "transmit buffer full" problem? Ray Link to comment Share on other sites More sharing options...
96RAF Posted October 28, 2019 Share Posted October 28, 2019 The baud rate affects data flow passing the instructions from the PC to the DCC controller hence to the screen. It has nothing to do with saving text files On the PC, which is likely to be a local permissions setting problem. Link to comment Share on other sites More sharing options...
pd91223 Posted January 1, 2020 Share Posted January 1, 2020 Just tried running this (as admin) on my Windows 7 system which is connected to Elink on COM1 (no actual Smart Screen connected yet). Before it loads fully I get an Unexpected Error message. I've tried running in Windows 7 compatibility mode, but same problem. [On my Windows 10 system, unsurprisingly, I get "no COM ports found".] Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 2, 2020 Author Share Posted January 2, 2020 Hello PD, Yes I've had one or two reports from people having problems running the program on any other OS than Windows 10, so for the time being W10 is the only way to run it. Unfortunately I no longer have any W7/8 pcs, so I am unable to drill down to the problem. Ray Link to comment Share on other sites More sharing options...
96RAF Posted January 2, 2020 Share Posted January 2, 2020 I still have an old XP machine and one that I updated to Win7 Ray, so I can crank them both up and give it a whirl - or did I do that for you already ??? - can’t remember if I did or not. Link to comment Share on other sites More sharing options...
96RAF Posted January 2, 2020 Share Posted January 2, 2020 I still have an old XP machine and one that I updated to Win7 Ray, so I can crank them both up and give it a whirl - or did I do that for you already ??? - can’t remember if I did or not. I did ...In work twixt Ray and me for those who are interested with positive results so far on Win7.. Link to comment Share on other sites More sharing options...
