Mr Rick Posted October 10, 2019 Share Posted October 10, 2019 HI, just got back into model railway and having a few teething problems. The Acceleration / Deceleration control program not working on my Select Unit Contoller the AC and dE displays not showing up on screen. Guess I'm missing something along the line, anybody any ideas please. Link to comment Share on other sites More sharing options...
96RAF Posted October 10, 2019 Share Posted October 10, 2019 What is the revision state of your Select so we can look at the correct manual.Check the first two numbers that appear on screen when you power it up e.g. anything from 10-30-03 to 16-30-03. 10 = v1.0 16 = v1.6, etc. In the meantime try a reset of the Select per the manual. It is assumed you are trying to change the accel/decell settings on a seperate programming track not on the main track along with other locos. Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 10, 2019 Share Posted October 10, 2019 Or Rob could have put his assumption another way - just like all Select programming, it can only be done when the item to be programmed is the only item on the track at the time. Link to comment Share on other sites More sharing options...
