fac Posted October 19, 2019 Share Posted October 19, 2019 I have two copies of railmaster which are stored on two differant laptops. Both have been registered and upgraded to allow speech etc at added cost. One laptop is used at least weekly to run the railway at my grandsons, the other is used at my home for occaisional use in support. So imagine my disgust when opening railmaster on my own laptop to be informed that it is being changed to an evaluation version and then that the evaluation time has passed . It was obvious from the form of instruction that it appeared known to be a legitimate version and to contact Hornby if i believed de registering was incorrect. I have been admirer of Hornby for many many years, but this was disgracefull and i ask that they restore the system i have purchased. Perhaps they can inform me of the neccersarry procedure to have my software re installed correctly. It has been updated in the past. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 19, 2019 Share Posted October 19, 2019 It is very much a shot in the dark to raise this issue just here in this post. For one thing, even if HRMS did read your post, they have no idea who you are (from the perspective of your activated account information). You would be much better contacting HRMS directly with your issue. Preferably through the 'Help' request feature in the RM help screen, with a 'fall back' of a direct email to support@rail-master.com Link to comment Share on other sites More sharing options...
96RAF Posted October 19, 2019 Share Posted October 19, 2019 Have you tried the simple expediant of entering the basic and Pro key codes again. Has anything happened to the laptop that could have affected RM registration, such as a new hard drive or even something as simple as the battery going completely flat. Has your anti-virus or ‘PC-cleanup’ software deleted a critical file or registry entry. As Chris says get HRMS directly involved and let them poke around your laptop remotely to see what has gone wrong so they can put it right. Link to comment Share on other sites More sharing options...
Peterdwill Posted October 23, 2019 Share Posted October 23, 2019 I have had the same issue today but I think I am more to blame then Hornby, I have sent the request via the help screen and I am awaiting a reply with new entry codes for my railmaster and pro packages, don’t supos anyone knows how long they take to reply Link to comment Share on other sites More sharing options...
96RAF Posted October 24, 2019 Share Posted October 24, 2019 You haven’t given us much to go on Peter about your problem, so I doubt you will get a sensible answer on here. Why would you need new codes unless you never had them in the first place. You should have had an immediate auto-reply from the help screen report saying they have received your query and will respond within a few days. If you didn’t get the auto-response you will never get a reply as they didn’t get your question. Link to comment Share on other sites More sharing options...
Chrissaf Posted October 24, 2019 Share Posted October 24, 2019 I agree. I think the likelihood of HRMS giving you new software key codes extremely unlikely. Fix (reset) your existing ones....Yes.......but give you new codes......no..TIP: As this is your very first post, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
96RAF Posted October 24, 2019 Share Posted October 24, 2019 When I had a problem reactivating my Pro code, HMRS would not confirm the key-code I said I had, merely suggestng I had a typo in a certain part of the key. I did have a typo due to not being able to read my own writing, but with HMRS prompting me I worked out what it should have been. Link to comment Share on other sites More sharing options...
RMRED Posted December 6, 2019 Share Posted December 6, 2019 I had a similar problem recently, caused by my de-registering the copy of railmaster on my laptop in favour of my old XP machine. When the XP machine went I had to get it deregisteed then re-register the laptop.HOWEVER the registration key on my laptops version was still visible on a panel which, as I remember, I invoked using the "?" button on the top. Worth a try? Link to comment Share on other sites More sharing options...
