TypsJunction Posted January 2, 2020 Share Posted January 2, 2020 So I purchased an NCE powercab the other day and it is performing well. I also have my hornby TTS MTU sound decider in my HST. Two questions, how do I switch the function buttons of the decoder? E.g make sound which is f2 and turn it into f4 for example. Also I used use a hornby select and all loco light would turn on at controller on. However with the NCE all lights are off and if you get what the hornby select would say is an overload on the NCE when you remove the overload the lights go off again. Is there anyway to get the lights to turn on during boot up and after overloads on the NCE powercab? Thanks Link to comment Share on other sites More sharing options...
Chrissaf Posted January 2, 2020 Share Posted January 2, 2020 ....how do I switch the function buttons of the decoder? E.g make sound which is f2 and turn it into f4 for example.....You can't.....the TTS decoder does not support function mapping..I can't offer any answer to your other question.... Link to comment Share on other sites More sharing options...
96RAF Posted January 2, 2020 Share Posted January 2, 2020 You cannot as Chris says reallocate functions on a TTS decoder but you may be able to reallocate some limited functions on the controller - read the famous manual as they say. Please report back if you can as others will benefit from your input. Link to comment Share on other sites More sharing options...
