96RAF Posted January 5, 2020 Share Posted January 5, 2020 I also have to go out for the morning, but I have already answered this question on RM Web forum. Link to comment Share on other sites More sharing options...
96RAF Posted January 5, 2020 Author Share Posted January 5, 2020 guys im hoping someone can help me out as im using an a R8247 decoder for my points an it works wellbut i have been aware of that you are able to change it from a short high power burst of power to a continuous output feed of powerwitch is exactly what i'm looking foras i have read the instructions that with it but i've noticed it only cover the Hornby Select an the Elite nothing there to tells you how anything regarding the Hornby E link controller as im iseing the Hornby e link controller as im using it with Hornby rail master softwareas im hoping sumone is able to help me out with this pleaselook foward to hearing from youThank you Gavin Link to comment Share on other sites More sharing options...
96RAF Posted January 5, 2020 Author Share Posted January 5, 2020 I have answered this post on RM Web forum earlier today. Chris - topic moved as requested. Did you want to hide your original post and repost your initial response again here. To recap connect your R8247 to the elNk Prog output, select the Point programming icon and select R8247 from the drop down. Ensure the correct addresses are present then select always on for the rewuired ports. Write this configuration to the decoder. If you had an earlier accessory decoder R8216 then it does not support always on, only pulsed. If you try to readback the settings the port addresses may not seem correct. Ignore this and reconnect the R8247 to your main track and check all is well. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 5, 2020 Share Posted January 5, 2020 Page 73 of the latest 1.72 RM manual.....extract replicated below. Note the yellow highlight..Basically you connect the R8247 to the PROG A&B output of the eLink. Open the Accessory Decoder configuration page (see manual extract below). Input the Port 1 address you want to use (the other three ports will be automatically numbered sequentially from the address assigned to Port 1)..Click the check boxes for the ports you want to make 'always on'. Then write the configuration to the decoder using the blue pen icon on the left.....not the green tick on the right..As simple as A, B, C./media/tinymce_upload/0f41f055e19542890b3c0d4511c33a0e.jpg.TIP: As this is your very first post, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button..Particularly as my reply includes an image. If you use the blue button, any reply you write, may be held back for image approval. Even though it is already a previously published image..See also – further TIPs on how to get the best user experience from this forum.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/. Link to comment Share on other sites More sharing options...
